Tire Pressure - Load Chart BFG KO2
What PSI do you run on Rubicon BFG KO2 LT285/70R17
  • Total voters
    117
Adventure.AS
Port Dover ON Canada
2020 JLUR
I found this load/inflation chart useful for my 2020 JLURubicon. Based on the door sticker of 3100 GVAR (front and rear) for my Jeep, the tire inflation sticker on the door of 37 PSI is too high for a load of only 1550 per tire.
This chart only goes down to 2105 lbs, so inflation of less than 35 for daily driving would likely be OK.
BFG KO2 LT285/70R17
35 psi for load of 2105 lbs per tire
40 psi for load of 2315 lbs per tire
45 psi for load of 2510 lbs per tire
50 psi for load of 2755 lbs per tire
55 psi for load of 2900 lbs per tire
What PSI do you run for highway use?
wanderer
Ralph
Carlsbad CA
Engineering Geologist
what is th emost comfortable and safe pressure for a rubicon running 315 17 70s BFG e rated?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
BFG KO2 LT285/70R17
I ran the stock 285's at 35psi cold, because anything lower triggers the tpms light on the dash. 32 felt better, but that yellow light was irritating.
Headbarcode
LI, New York
I'm now running 315's, but the C rated ones, at 30psi cold. Those E's are pretty stiff for a wrangler. What size wheel? If stock, you'd have to run them pretty low to pass a chalk test.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
For me, on airing up, the light goes away at 35 psi, but you can then lower it down to 32 without triggering the light. The low threshold is something like 30.
Headbarcode
LI, New York
Oh, I did not know that. I switched to 35's and got the tazer mini before having the chance to play with the system on factory settings. Thanks for that though! I now have more info to pass along to the next person.
Have a great day, Jerry!
