Roky
We’re narrowing it down, lol, hopefully it’s the tires.Yes , currently running falcon adjustable but have also tried MC stabilizer and oem with no change in pull.
I sure hope so, thanks!!!! Merry Christmas and thanks for your time and suggestionsWe’re narrowing it down, lol, hopefully it’s the tires.
No problem, let us know how you make out... merry Xmas.I sure hope so, thanks!!!! Merry Christmas and thanks for your time and suggestions
Yes, correct. I typed incorrectly.Ive always run higher caster on passenger side to compensate for crown in the road.
I'm still not understanding how you can set driver and passenger caster different on a live axle. Is there that much flex in the axle assembly that it can be adjusted? Wouldn't that put undo stress on the control arm joints trying to force a caster adjustment left or right?You want more caster on the passenger side, not the driver side. .2 to .4 degrees more is a good split. If you're still having pull issues I'd check your that your rear axle is square to the frame (use a measuring tape from one of the body bolts). If that checks out see if you can mount up another set of wheels/tires to see if those tires are the culprit.
That’s my concern also, but after having multiple 4wd shops set arms differently and coming up with different cross caster numbers, it must be possible, but how much twist or bind it causes or if it helps, I do t really know. I know I’ve had more caster on pass side before .3 split but still had pull, so.... on to different tires to see it that’ll help first before I change arm length on pass side I guess.I'm still not understanding how you can set driver and passenger caster different on a live axle. Is there that much flex in the axle assembly that it can be adjusted? Wouldn't that put undo stress on the control arm joints trying to force a caster adjustment left or right?
We're talking about fractions of a degree. They are likely set up with a small amount of cross caster from the factory.I'm still not understanding how you can set driver and passenger caster different on a live axle. Is there that much flex in the axle assembly that it can be adjusted? Wouldn't that put undo stress on the control arm joints trying to force a caster adjustment left or right?
I see that you've had problems with pulling to the right before. Please remember that all of the numbers that you are getting out of your alignment are also dependent on the on the squared-ness of your body, accuracy of holes in the frame, and the sum total of all of the +- tolerances of everything between the frame to where the rubber contacts the ground, not to mention exactly how accurate your shop's alignments actually are.My understanding is with a solid axle the cross caster is built in to the axle and you can’t really adjust each side individually to adjust for more or less caster without twisting the axle? That makes sense but I hear of people saying all the time just add more caster to one side, or that when installing lift they put LCAs at different lengths. I’ve been dealing with a pull to the right, my cross caster is just slightly off and everything else seems good but was curious if I could adjust LCA or UCAs on pass side slightly to possibly help increase caster to help get rid of pull to the right without causing joint bind or some other drivability concern with making that adjustment, or if it would even do anything to help. I’ll attach my most recent alignment printout. Also, I guess it could be tires (37” STT pros 28psi) but I’ve tried cross rotating and the pull to The right is still there And didn’t change . America’s tire said they’ll swap out 2 tires to see if it’ll help but believe the alignment is off causing concern. Any ideas, thoughts, or suggestions? TIA and Merry Christmas
Current mods and measurements
LCA- 24 7/16
UCAs-20 1/8
3.5 Mc lift
Mc tie rod
Mc drag link
Teraflex adjustable front UCAs and LCAs
Falcon stabilizer
Yeti track bar
There was a thread about the STT pros pulling right:Also, I guess it could be tires (37” STT pros 28psi) but I’ve tried cross rotating and the pull to The right is still there And didn’t change .
