The Tire Carrier Thread
2018 Jeep JLU
I also have the Smittybilt relocation bracket installed on my JL with a 35” spare. The rubber pieces are making constant contact with the spare tire and yet it vibrates A LOT, even over small bumps. I can’t imagine this is good for the tailgate. Looking for another solution now, as I’m definitely not going to keep it this way. Pretty disappointing
I’ve experience the same thing. My Smittybilt has a 37 on it and it jiggles like Jell-O. I’m going to need to replace it soon
Stickerhead
McKinney, Texas
2018 JLUR, 1997 TJ on 37’s, 2017 Powerstoke Tow Pig
I used the RC relocation bracket. It is well made but locates the tire way up. I added some fabricated bumpstop extenders made of plastic tubing and PVC caps to the factory bumpstops. No squeeks or rattles
Rubi-Zero
Rubi-Zero
Nashville, TN
JL Rubicon , Audi S5
@Motobilt what is the max tire this carrier will be able to hold, 37”.... 40” ?
Rubi-Zero
Rubi-Zero
Nashville, TN
This is Motobilts JK version of their carrier, looks to be pretty solid. Hopefully they will post up a video like this for the JL version soon.
I wonder how it will compare to the EVO body mount carrier.
Hubtech
Kyle
Hattiesburg, ma
OB JKUR
I'm told in a couple weeks @Motobilt will be releasing their JL carrier.... i certainly hope so.
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
It will hold a 37" for sure. Testing out the larger tires currently and making some tweaks to it.
Jeep Wrangler JL The Tire Carrier Thread 45748596_10156934672747052_4292580913386094592_o.jpg?_nc_cat=104&_nc_ht=scontent-iad3-1
x7tristan
TJ
Maryland
What are some tire carrier options other than EVO, that will push back a -12mm offset wheel closer to the tailgate, thus preventing the backup sensors from detecting the spare (current issue I'm having with stock carrier and LoD relocation bracket)? EVO option looks great and all but that backup camera/brake light solution doesn't seem feasible for long term use/abuse.
Jeep Wrangler JL The Tire Carrier Thread IMG_20181112_164543
Stickerhead
McKinney, Texas
45748596_10156934672747052_4292580913386094592_o.jpg?_nc_cat=104&_nc_ht=scontent-iad3-1.jpg
That arrangement will not work with backup sensors. I tried my 37 on stock carrier and worked great until I went to back up. That’s why I went to relocation to clear sensors. Looks like it is about the same height.
Rubi-Zero
Rubi-Zero
Nashville, TN
Well it really will depend on how far your tire and wheel combo sticks out and if it’s in the path of the sensors.
It looks like Motobilt and the EVO carriers are much closer to the gate, so this allows more clearance from interrupting the path of sensors and will allow one to run a lager tire.
Motobilt is still under testing this carrier so they will know what will work when it’s done.
A 40” tire may have to mount higher up to clear the sensors path depending on the offset of the wheels being used, or maybe 40” is just too much tire to be able to work with the sensors all together.
I guess we will just have to wait and see.
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
Our carrier has multiple adjustments to move it up or down and forward and back. You will be able to move the tire back to the point where it is actually touching the carrier itself. We do not reuse the factory mount but rather provide a new heavy duty adjustable steel mount.
x7tristan
TJ
Maryland
what will your solution be for the camera and 3rd brake light? hoping something more stout than what the EVO solution looks like.
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
T
Haven't seen theirs but ours will mount in the center of the tire
