Dynomite1371
So, this is possible with the JL's? If yes then a yearly flush and or regular coolant will prevent the problem? Why should they use this stuff, likeFor those that don't know.
The newer JKs switched to an OAT type coolant. It's pinkish purple in color. It's an FCA color dye for them to tell which type it is (as opposed to coolant green). It forms a sludge after time and likes to collect in the heater core. When it's clogged up, the driver side of the dash won't blow warm air anymore. replacing the core on a JK is a huge feat (dash removal, etc.) - so it sucks bad.
By the time to have the cold air issue happening, your core is likely gone.
Here's what the sludge looks like at the bottom of the overflow bottle:
Here's the coolant in a mason's jar:
It's just not the JKs that have this issue. It's all the FCA rides that use the same OAT coolant. The above mason jar is from a Chrysler 200.
