I had the same issue on my JK for over a year and I spent a mint replacing front end parts with no end in sight. Then one day I had the rear end off the ground with it on jack stands and I realized that there was play in the driver side axle mount for the LCA. Pulled it off and the hole was wallered out allowing the arm to move around. I had a shop weld on a new tab and redrilled it and the Jeep drove wonderfully afterwards.Hello everyone. Prospective buyer here.
I've been to several dealership test driving different models. Really trying to decide if I should keep my truck, or trade it on a JL.
Anyway, I have owned 2 Jeeps in the past. A 1988 YJ (I think that's the year) that I owned in the mid 90s, and a 2007 JK that I owned in 2010. So I am familiar with Jeep solid axles.
I also test drove 4 total Jeeps so far. a 4-door sport manual, a 2-door Rubicon Automatic, a 2-door Rubicon Automatic with the 2.0, and now a 2.0 4-door Sahara.
All bone stock, all from dealership lots with a salesperson sitting right next to me.
The Sahara was really difficult to keep pointed straight down the road. It kept wandering all over the place. Obviously this isn't normal, as none of the other jeeps did it.
One thing I noticed when driving it with my hands off of the wheel, when accelerating it made the jeep steer to the left. When decelerating it made the jeep steer to the right.
Now this made me think it's a rear axle issue causing this wandering. Does this sound right?
It's got me a little worried about buying one. Are there any resources to read up about this?
I don't have to buy a jeep this year, I can certainly hold off another year or two until this problem is fully worked out. This wandering issue has me considering this.
Did the pull change depending on whether you were accelerating or decelerating?I had the same issue on my JK for over a year and I spent a mint replacing front end parts with no end in sight. Then one day I had the rear end off the ground with it on jack stands and I realized that there was play in the driver side axle mount for the LCA. Pulled it off and the hole was wallered out allowing the arm to move around. I had a shop weld on a new tab and redrilled it and the Jeep drove wonderfully afterwards.
Yes, accelerating caused it to yaw to the right, letting off the gas caused it to yaw to the left.Did the pull change depending on whether you were accelerating or decelerating?
Thats the part that gets me, makes me think this Sahara had something loose in the rear end.
I had a 2013 Rubicon, a 2016 Rubicon, and then (which is what i drive presently) a 2018 JL Rubicon. Aside from the aesthetics, the JL felt very different from the nearly identical 2013 and 2016 models. I recall driving down the highway on the way back from the dealership and really noticing the sensitivity of the power steering. So much so that I was half mentally preparing for being pulled over for swerving around. It wasn't a consistent pull one way or the other, it was more like a pull away from center.One thing I noticed when driving it with my hands off of the wheel, when accelerating it made the jeep steer to the left. When decelerating it made the jeep steer to the right.
There are many threads on this issue. Here is just a few of them. My "loose" steering was improved with a new steering box. I still have the wondering issue even after replacing the steering dampener, track bar and the LCA's....all after market parts.Hello everyone. Prospective buyer here.
Same here, my JLU Rubi is still at 41psi as purchased, 4k miles, drives well. I'm also getting 24 to 25mpg... I'm a little hesitant to lower the pressure and kill the milage.My 4-door rubi came with 44psi and we put 5,000 miles on it before I aired the KO2s down, yet it still drove like a champ. So strange how these vary. I ran it up to 85 on a 2lane highway and it still drove perfect. Odd.
Funny because I was debating on whether to buy a JL after reading about so many steering/wander issues.
I wonder if what's really happening is there's a physical dead zone in the steering rack, but the steering wheel's angle sensor doesn't have a matching dead zone in the software. In other words, supposing your wheel is like 0.25 degrees off center, that obviously won't cause your front wheels to turn. Maybe the electronic power assist sees that, and it was designed for a car where 0.25 degrees off center would actually cause the front wheels to turn, so it kicks up the assist just enough to turn the wheels.However, in my new JL, if I nudge the wheel right or left, the JL tracks in the direction of the brief steering wheel rotation without returning to center track as one would expect in a normal steering system. The result is that with each minor steering correction, the new JL requires a subsequent counter correction to keep it on track.
Probably not. If that were the case, it would be a software fix and Jeep would've already taken care of it.I wonder if what's really happening is there's a physical dead zone in the steering rack, but the steering wheel's angle sensor doesn't have a matching dead zone in the software. In other words, supposing your wheel is like 0.25 degrees off center, that obviously won't cause your front wheels to turn. Maybe the electronic power assist sees that, and it was designed for a car where 0.25 degrees off center would actually cause the front wheels to turn, so it kicks up the assist just enough to turn the wheels.
