Geronimo
I have after market sensors. Unfortunately they are mounted in Hutchinson bead locks. I know when I purchased these, Discount Tire programmed these for this JLUR specifically with a hand held programmer. These were not cheep knock off type, but are indeed "quality" aftermarket from big name supplier of these. That is really downer. I will not disassemble these wheels until tire wear deems it necessary (major PITA) but will change the sensors out with the ones that came with the Jeep (eventually)
Sure wish I had known this going in I would have done things a bit different. I am giving the KO2s to my daughter for her new Chevy truck and will take the sensors out of the factory wheels at that time.
I appreciate you suggesting that as the problem, I believe you are most likely correct. I PMed ZA but suspect they will confirm your suspicions as well. This is my wife's DD so I really wanted to monitor pressure, but we will see if we can ignore the light for a while anyway. May have to disable the TPMS completely until tire swap.
Thanks WranglerMan
Thanks WranglerMan
