Tazer JL - more than just a tire size programmer!
NavyVet1959
OldFart
Texas, ya'll
XJ (sold), WJ (sold), Ram 1500 QC 4x4 (sold 2018.06.07), Wrangler JL Sport 2-door (ordered 2018.06.08)
Retired engineer (NASA, aerospace, DoD); ex-Navy
As far as I'm concerned, if you want "passive" entry, then just leave your doors off. :)
Seriously though... I would not rely on the system deciding when to lock or unlock the doors. I just don't trust the kiddie engineers these days to get it right and not make some sort of logic mistake that under certain conditions results in you getting locked out of your car or not being able to start it. Hell, I explicitly order the "Sport" model just so I would not have electric windows and door locks.
mike_b_81
Iowa
2019 JLUR
I received my Tazer JL today, set my tire size, disabled auto start/stop and tried to set DRL. I had purchased and installed switchbacks in hope of making the white lights the DRL. But when I select turn signal as DRL, it's just the orange light that is on. Is there anyway to make it where the white light is on?
IPvFletch
Kevin
ATX
JLUSS
This only works if you have DRLs installed/enabled. I don't think you can just enable it on the Sport, you need the wiring for it, too.
mike_b_81
Iowa
2019 JLUR
Drats! I can set any other light to be a DRL, in the interim I have set the fog lights as my DRL.
Rhinebeck01
2018 2dr. Rubi
Figured I would mention here, in case any of you 2.0 Turbo owner's might be interested........
Anyway, the Tazer JL and Tazer JL Lite do the deed lets say with a 2.0, just as they do the deed with the 3.6.
Actually, I believe the Tazer JL and Tazer JL Lite are presently the only JL programmers that work with the 2.0.
Boatbuilder88
New Jersey
'19 Wrangler JL Sting Gray
Hi Z Automotive. I heard that a future update to the Tazer JL will have a hood alarm feature. When will this be available?
UNC Rubicon
Bret
Kernersville, NC
2019 Billet Silver JLUR
Why do you say that? I found a video on a FB Jeep JL group that demonstrated the alarm. Shouldn't be that hard to make use of the hood pins.
@[email protected] definitely posted a teaser on Facebook regarding the hood alarm. I’m guessing on the next update which shouldn’t be too far down the road.
Jimmylats JL
Fort Knox
2004 Jeep TJ willys, 2018 rubicon JLU
I have a rubicon with 35's. Does this help with the shift points on the automatic? I know you can change the tire size with the programmer, I am just wondering if you change the tire size, it would somehow affect the way the computer recognizes the shift points and changes them in a positive way to correct for the tire size.
Rhinebeck01
2018 2dr. Rubi
Yes, once you use the dealer does the programming for tire size or you do it yourself with a programmer, the automatic transmission will over time, adjust the shift points automatically.
Rhinebeck01
2018 2dr. Rubi
@everyone
Do know that ZAutomotive is offering 10% off of EVERYTHING for Black Friday.
Use the Coupon Code: BLACKFRIDAY
Bearman95
Chuck
Ft. Worth
2018 JL Rubicon
Hey guys, for you with 315 70 17 BF Goodrich KO 2 tires, what are you setting the Taser at for your tire size? My original settings was 32.5 as I have a Rubicon and originally had to 285 70 17. Any comments will be appreciated!
Rhinebeck01
2018 2dr. Rubi
@Bearman95
Suggest you use 34.5 . After this, with a smart phone and GPS, do check to see if your speedo is accurate. If not accurate, go up or down size wise until you get it right. Do check accuracy at say 30, 50, 60 mph.
Bearman95
Chuck
Ft. Worth
2018 JL Rubicon
@Bearman95
Thank you a lot for the comment!
D&C Designs
