James_a
- James
- Aug 19, 2018
- Alameda, CA
- 2003 Rubicon, 2018 JLU Rubicon
Thanks again Sean for all your input!The black plastic surrounds (large one at the bottom and the small one at the top) both pop out easily. You can carefully use a screwdriver or better yet get some cheap plastic trim tools from HF. That will give you plenty of room to guide the cable from the top port over to the right, then down to the bottom. Removing those ports is the key, so you can get your hand in there and help fish it through. You could also use a fish tape from the bottom up, but I didn't need to on mine.
@paulr has the hardtop liner that covers his ports, so that may be a little more involved to remove so you can pop out the plastic ports. I don't have that back liner on mine.
I completed my install today with a few personal touches. Brawlee led strip on the glass and an LED strip on the the top of the cab. The LED strip in the cab is glued onto a velcro strip with the other half of the velcro adhered to the headliner with iron on Velcro.
Both lights are controlled by switches with the LED in the cab tapped into the dome light and the brawlee tapped into the 12v supply. Both switches have red LED rings powered by the dome light so their only lit when the dome light is on.
All the wiring is as hidden as possible.
