Tailgate bolt removal. How difficult?
K9WG
Richard
Greenfield, Indiana
2021 Wrangler 2-door JL Firecracker Red
Retired - Well kind of.... Electronics associate for a defense contractor. 2nd career :)
I want to install the TeraFlex antenna mount on the tailgate hinge. This requires removal of the T55 bolts and replacement with a bolt for the mount. I have been reading where there have be problems removing the T55 bolts. It looks like most of the issues stem from using the incorrect size or not fully seating the Torx bit. I have the correct bit (T55) and am going to remove all the extra paint on the bolt. Once I start to remove the bolt will I encounter a large amount of resistance? Anyone else have experience in removing the hinge bolts? I just want to make sure I don't break or strip the bolt.
Thanks
Richard - K9WG
Deleted member 102807
Guest
Initially it will be a good amount of resistance, however keep even pressure and it will ā€˜pop’. Then it’s pretty much finger easy to remove them. Also you don’t need to remove any paint.
jadmt
jeff
montana
I just installed a mopar hd hinge and on my 2024 they came out easy but I have been doing this kind of thing for a long time. push hard on the ratchet to keep the torx bit fully engaged and start with a slow turn..
cram501
Eric
Ashburn, VA
2019 JLUS Mojito! Moab
You just need to ensure the Torx bit is fully seated. A few taps of a hammer will help. After that, even pressure should get it to pop loose although it may take some effort. I used a breaker bar on mine and had no problems.
K9WG
K9WG
Richard
Greenfield, Indiana
OK - Thanks! I will grab another cup of coffee and give it a try this afternoon...
Richard - K9WG
Nokones
Kenny
Sun City West, AZ
It is a piece of cake. Just use a real Torx Bit like an older Craftsman or Snap-On, or Proto and not a Chinese POS that you buy from a cheap discount tool retailer or from a third party warehouse enterprise operation that doesn't specialize in any specific or proprietary product or service that only sells cheap POS inferior foreign products.
Jeep Wrangler JL Tailgate bolt removal. How difficult? 20241128_074528
I like the Tekton brand. They haven't let me down. But it looks like they may have discontinued their manual impact driver.
Terrymo
Terry
2023 JLURXR 3.6 ET
In the videos I see, people are gently tapping the bit in place. Then applying inward pressure on the head of the ratchet or breaker bar while turning. Skip to the 5 minute mark. Ignore the rest of the vide….or not.
If I got the skinny blonde to come over and loosen my tailgate, my wife would probably use some vise-grips on my Torx bit.
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
This! I also but the tailgate reinforcement on and the bolts come out with some pressure but make sure you keep the torx bit fully seated. Great tip!
K9WG
K9WG
Richard
Greenfield, Indiana
OK - I was able to remove the bolts without any problem. I did have to use an extension on the ratchet to get one of the loose. TeraFlex mount and antenna installed...
Thanks all.
JPAloha
Saskatoon
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE, 2018 JL Rubicon 2 door
Accredited Financial Planner
I’ve put the Mopar reinforcement on two of our three and the Teraflex antenna mount in two of the three. Only had one bolt break of the ten undone and that was likely my fault.
Hope it goes well for you.
