Sway Bar Link Swap
Ronin81
Jason
2018 Wrangler JL
Hello JL Crew,
To start off, I have a 2018 2-door JL.
Has anyone seen or have these sway bar links (pic #1)? I purchased this Jeep and to my knowledge, all suspension parts are OEM. I was getting a rattle and found it to be the rubber on these links is wearing and the recommended torque on the bolts is not holding.
I have made two attempts at ordering replacements. The first set were too short and the second set (pic #2) too long. Is there any reason(s) not to use the longer set?
The original links have two female ends. The ones in the second picture and all those I can find online have one bolt built in and one female end.
Any advice or direction is greatly appreciated.
Jeep Wrangler JL Sway Bar Link Swap IMG_0246
Jeep Wrangler JL Sway Bar Link Swap IMG_0172
Roky
Roky
Hello JL Crew,
You can use the longer ones, it’s ok if the bar is angled up slightly….
JL 2D
Jason
2024 Rubicon XR
Sure it’s a JL and not a JK? 2018 was a crossover year. The specific model makes a difference.(rubicon, sport, etc) Go to parts.moparonlineparts.com and enter your VIN, then search the parts you want.
Swaybar not being at 90 degrees is not ideal but also not going to make a big difference in performance.
Ronin81
Ronin81
Jason
2018 Wrangler JL
I know mine is a JL but to show I am here for help, I looked up my VIN and got the following
2018 Jeep Wrangler Sport 4WD (6 Cylinders G 3.6L MFI DOHC 220 CID)
PotterJLUR
Kansas
www.youtube.com
2024 392 Rubicon, RAM TRX, Camaro ZL1 1LE
Those are cheap rough country front sway bar links that are currently installed, I would defiantly run the new mopar links you bought that are slightly longer, they will work great but you will need to order the OEM nuts that go on the sway bar link studs.
Also please post a picture of the top of you front spring so we can see if there is a spacer installed.
Ronin81
Ronin81
Jason
2018 Wrangler JL
Thank you for finally getting me the answer of the maker of the current links.
Here are the pics. Hopefully this shows you what to you asked. I took one from the front and back.
Jeep Wrangler JL Sway Bar Link Swap IMG_0250
Jeep Wrangler JL Sway Bar Link Swap IMG_0251
PotterJLUR
Kansas
www.youtube.com
Yes that Jeep has a 2in rough country spacer lift installed
Ronin81
Ronin81
Jason
2018 Wrangler JL
Would you agree with, “You can use the longer ones, it’s ok if the bar is angled up slightly”?
Ronin81
Ronin81
Jason
2018 Wrangler JL
Thank you to all who replied and helped. I felt comfortable with swapping the parts. Here are the results.
Jeep Wrangler JL Sway Bar Link Swap IMG_0254
Jeep Wrangler JL Sway Bar Link Swap IMG_0255
