Suitable Trim Level and Other Options
embedded rock
In the path of a future Kentucky tornado
'24 JLUWX (traded) | JLRX for EJS'27? Let's see | CRF1000L, KLX300SM
Hey there Jeepers! (hopefully that's not offensive)
Have been researching, reading about, and building a Wrangler at the Jeep site for quite a while now. Recently drove a '21 JLU with an auto and about 43k miles. Back in '80 or so, I drove a CJ5(?) that wouldn't track straight. That's it. That's my Jeep experience.
I want one as a second vehicle to my F150.
This JL would be used for around town and short trips. Then, during the summer it would be be roaming the Rockies and forest service roads, etc.
For awareness, I have ridden a motorcycle through the Alpine Loop in Colorado twice; but, have never ridden Black Bear. This is the type of driving I would do with the Wrangler too. Never back to the Alpine Loop again due to the crowd; but, you get the idea.
So, what is an ideal trim and/or options that would be sufficient for my future JL?
Most likely a pre-owned JL fits the budget better; but, I'm now starting to see mark-downs on new 2-door Wranglers as much as $4k.
Jeep Wrangler JL Suitable Trim Level and Other Options IMG_20180716_135802387
Jeep Wrangler JL Suitable Trim Level and Other Options IMG_20180717_121413575
Jeep Wrangler JL Suitable Trim Level and Other Options IMG_20180717_130643789
kah.mun.rah
Merenkahre Jr.
Duat
Same thoughts as @failsafe306. IMO the best bang for the buck for a Wrangler that spends time on and off-road is a Willys. If it's in the budget, a Willys with the XR package I think is better than a base Rubicon.
Some Random Guy
Washington
Comptroller
You say short trips and you aren’t super Jeep savvy.
Would you consider a plug-in hybrid? Look up the 4XE. I know you said you were targeting used, but if you only burn gas on pleasure trips you might find the 4XE worth it.
Otherwise almost any Sport, Sport S, or either Willys trim seems good for you. Just avoid Sport or Willys Sport if crank windows and manual locks aren’t your thing.
vetygud
Michael
Nisswa, MN
2022 Jeep Willys 2 door Sarge
Retired LEO
Willys would fit the bill. It would get the job done until you put miles on and decide if and any upgrades are needed.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
I weirdly love my crank windows.
Xcoaste
Ben
PA
2021 JLUR - Past - '13 JKU, '97 TJ, '93 YJ
Whatever fits your budget will do the trick.
They are all more capable than the CJ5. Good set of tires will take you almost anywhere.
Valpo Jeep
Doug
Valparaiso IN
15 Mas Ghibli, 18 JLU, 05 Gulfstream RV
We have a Sport S and so far like it a lot, what does the Willies offer over the Sport S?
embedded rock
embedded rock
Thanks for the comments and suggestions everyone.
Tires are a bit of a priority as I would prefer to not have to go straight to the tire shop after buying new or used. This is where the Willy's trim has an advantage. Or, a used JL without the street tires.
Engines. My preference is to not have a turbo--same reason I have the 5.0 v8 in the F150. So there are two versions of the v6 for the Wrangler and I understand one has e-torque. Looking at this infor it would seem there are two batteries as the website lists "auxiliary battery" as standard.
Question is are there really two batteries? A week ago I asked a sales guy at the local Jeep dealer and he didn't know the answer. I had suspected that the e-torque would have an aux battery; but, no definitive answer. (I know the I4 turbo engine has an aux battery near the rear axle.)
Jeep Wrangler JL Suitable Trim Level and Other Options 1678634680631
embedded rock
embedded rock
Get the m220 heavy duty rear axle. Also called a Dana 44
ask your dealer and double check the official build sheet. You can put an Eaton true trac in it When the mopar limited slip clutch wears out.
willys and Willy’s sport have it.
anything with the mopar limited slip has the bigger rear axle.
this is the only thing I regret not getting on my lowest cost sport.
hindsight I would have got the Willy’s sport
things that are hard to upgrade
. Axles
. Power windows and locks almost impossible To add later.
easy upgrades
tires
rims
lift
bumpers
medium upgrades,just cost money
eaton thru trac for your front axle, or a torque locker
rubicon takeoffs. Lockers, axles, etc.
Having the "Anti-Spin" covers the axle choice, right?
Javwohl
Denver
17 vw gti, 2001 dodge ram, 202 jlurd white, 2005 mazdaspeed Miata lava orange
engineer
To answer your battery question yeah both v6s have an extra battery the v6 with ess has a second battery up near the first but it is the size of a motorcycle battery, the etorque v6 has a standard battery in the engine compartment and a 48v underneath.
There is stores about issues with the smaller battery in the ess and ways around it. Have not seen issues with the 48v in the etorque.
Hope this helps.
embedded rock
embedded rock
Hope this helps.
Thanks for confirming the dual batteries. Now, those make a case for the upgraded alternator that comes with the tow package.
Javwohl
Denver
engineer
There is a lot of advantages to getting the tow package even if you don’t plan to tow, the bigger altanator is one of you don’t go with the etorque v6, also the standard battery is bigger and you get the aux switch’s and working all ready installed. If you plan to run any accessories it’s a good item to have.
