Suggestions for leveling out
Byrds8
Since I installed the steel bumper, my front in dropped about 1/4". Since the Jeep already had some rake, it made it worse. What would you guys suggest on leveling it back out? I am not looking for some crazy lift or anything. Especially something that would cause me to have to get adjustable LCAs to fix caster etc. Just something to make it look better and not change her ride, especially for the worse. Thanks.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
Not sure how much you need in the front, but you could just get a spacer lift kit and only use the fronts. They sell them in small increments like .5" and .75" if you don't need a whole inch or more.
At Risk Ute
Christian
ā€˜23 392 XR
Retired Navy
Longer MOPAR LCAs (more for caster / better drivability) and 1ā€ pucks up front. I’ve still got a little rake with 3/4ā€ pucks.
Under $200 and easy shade tree install.
Jeep Wrangler JL Suggestions for leveling out IMG_2316
Jeep Wrangler JL Suggestions for leveling out IMG_5447
kah.mun.rah
Merenkahre Jr.
Duat
Unless the High Tide already comes with them, maybe swap out with some Rubicon coil springs.
Byrds8
Byrds8
The High Tide is an XR. So even with that, not sure HOW they gave it a 1.5 lift. Was it solely due to springs? Should I just go with a puck up front and be done? Id have to have someone put them on as I have never done it though lol.
As for the MOPAR LCAs, they are already on. It was close to one of the first mods I did. I just dont want to lift to the point I need adjustable to regain caster that I already added with the LCAs.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Puck/spacers are 1:1 alteration to ride height at the axle. If you want 1/4", just add 1/4". It's just putting it back where it was, so won't impact anything compared to where it was (other than the slight increase in weight impacting the driving characteristics).
Byrds8
Byrds8
What would be needed total to level? I know the 1/4 it dropped but had there been no dro what else?
GATORB8
CLT NC
Pull out the old measuring tape. Remember the rake is there so you can carry payload or tongue weight out back.
I wouldn't measure fenders, the rock rails are probably a good spot.
Byrds8
Byrds8
Ha. Sad that didn’t dawn on me rofl. Maybe I should just leave it alone then. I don’t tow too often. But the level look looks so much better.
GATORB8
CLT NC
Certainly up to you.
Have you had any issues with the front bottoming out when driving?
Byrds8
Byrds8
Nah no bottoming out. Guess I’ll have to think on it some. 1/2ā€ isn’t too much of a lift though so may do it. Who knows lok
Byrds8
Byrds8
Measuring from the bottom of the pinch weld? there is about an inch difference between the front and rear. So, I assume, if I put a 1/2" spacer on the front to more level it out, it would look much better and still give a slight rake for any tongue weight on a tow? I also assume with such a small difference, there would be no noticeable difference in driving characteristics.
GATORB8
CLT NC
Yup.
