White Rubi
I would like to pass on some info that may help someone else with this problem. I just recently had to replace all my studs because they were over torqued and the splin nuts broke at the tapered end. I tried the tool that you beat on then stick a ratchet on it and it should backoff. That didn't work. So I tried drilling the studs out that was slowly working but then came to a sudden hault as I got to the outer edge of the stud. Well then I tried torching out and that made a nasty mess so then I had an idea. I took a 3/4 hole saw took removed the pilot bit used the stud as a guide and cut the lug nut off. It left just enough on the stud that it still slid through the holes for the studs. That took about 15 - 20 min a lug to cut off. It will take about 2 hole saws for every 3 studs. I hope this helps anyone else.
