Jeep&dogs
- Jim
- Aug 11, 2019
- Cedar Lake
- 2020 JLUr
If you were to build a plate that contours the outside of the frame and attach the gussets to that plate, you could then enlarge the holes on the outside portion of the frame only, then install the plate. The gussets would bottom out in the inside of the frame and when you bolt through the outer plate you would basically have what was on the older Jeeps. No welding involved
