Splain fender static charge
JHTS
John & Holly
Hope Mills NC
21 Gecko JLU Freedom, 20 Punk'n JL Sport S, 91 Mustang GT, 25 Ranger XL
John - US Army Ret/DA Civilian
So I was in the garage walking close past the Jeeps and the hair on my arms stood up and pulled towards the plastic fenders. Tested it on the other Jeep same thing when you wave your arm an inch or so but don’t touch the fender the hairs pull straight to the fender. Can someone explain that, just curious I’m obviously not that smart.
Sparty
SW Michigan
04 TJ, 21 JTR, 21 JLR
Static electricity
Environmental conditions
Tends to happen more in the dryer months.
Stop rubbing on your fenders
ArcadeTracks
PJ
Pittsburgh, PA, USA
It's so you can say you had a hair-raising adventure with your Jeep, even if you never left the garage! ?
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
I am shocked by some folks’ static responses to this thread. This guy asks a serious Jeep question, and all he gets is verbal discharge from people. If I were him, this would make my hair stand on end, and I would bolt out of here. ⚡?
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Jeep Wrangler JL Splain fender static charge QB44N1iwGN53hAQ46L
Static electricity is defined as an imbalance of electric charges in a body, especially the negative and positive charges. In other words, the discharge of an electrical pulse is known as static electricity. Physical techniques are used to create the charge imbalance. Contact between solid things is one of the most prominent sources of static electricity. The static electricity generates a force during its creation which is directly proportional to the charges of both the bodies in contact and inversely proportional to the square of the distance between them. It is known as electrostatic force and is denoted by the symbol F. Its standard unit of measurement is Newtons (N), and the dimensional formula is given by [M1L1T-2].
Static Electricity Formula
F = 1/4πε0 (q1q2 / r2)
Where,
F is the electrostatic force,
1/4πε0 = k0 is the Coulomb’s constant with a value of 9 × 109 Nm2C-2,
q1, q2 are the charge values,
r is the distance between the bodies.
Derivation
Consider a system of two bodies of charges q1 and q2 such that they are separated by a distance r. It is known that the static electricity force between these two bodies is directly proportional to the product of the charges of the bodies.
F ∝ q1q2 ⇢ (1)
Also, the force is indirectly proportional to the square of the distance between the two bodies. So we get,
F ∝ 1/r2 ⇢ (2)
From (1) and (2),
F ∝ q1q2/r2
Replacing the proportionality sign with a constant, we get,
F = k0q1q2/r2
Here, k0 is known as the Coulomb’s constant.
This derives the formula for static electricity force between two charged bodies.
ArcadeTracks
PJ
Pittsburgh, PA, USA
You could probably make balloons stick to the fenders if you first rub the balloons on your shirt! :)
But, it is most likely static electricity, not some random electrical pull, or something else -- which would be ... concerning.
JHTS
JHTS
John & Holly
Hope Mills NC
Static electricity
My fenders like to be rubbed but i wasn't just surprised that plastic held a static charge,
JHTS
JHTS
John & Holly
Hope Mills NC
Are not Jeeps always a hair raising adventures?
JHTS
JHTS
John & Holly
Hope Mills NC
If you stopped caressing, and loving on your Wrangler so much, there wouldn't be so much electricity between you two.
Then my Jeeps would be unhappy.
JHTS
JHTS
John & Holly
Hope Mills NC
I dont have a 4XE so I had to drive out.
brennaman
Phil
MO
2009 WK 2014 JK, 2021 JLR snazzberry
damn near retired
Where,
Derivation
F ∝ q1q2 ⇢ (1)
F ∝ 1/r2 ⇢ (2)
From (1) and (2),
F ∝ q1q2/r2
F = k0q1q2/r2
Nerd. :giggle:
JHTS
JHTS
John & Holly
Hope Mills NC
Where,
Derivation
F ∝ q1q2 ⇢ (1)
F ∝ 1/r2 ⇢ (2)
From (1) and (2),
F ∝ q1q2/r2
F = k0q1q2/r2
Thanks for the detailed explaition. There was not contact the fenders had a static charge, both Jeeps we in the garage without being driven for over 24 hours. Just wondering why the fenders had a static charge.
JHTS
JHTS
John & Holly
Hope Mills NC
I sure it would but then i would be generating the static charge, the fenders had one for some reason.
Speed331
Sean
Las Vegas, NV
I was just giving you the formula. How the charge originated, I leave as an execise for the student.... perhaps the differential lies in you - do you wear lots of wool? ?
