No charge in cold weather
Greco78
Greg
Canada
2023 Jeep Rubicon 3.6L
I have a 2023 Jeep Wrangler Rubicon 3.6L. When the temperature drops below -25C (-13F) my battery loses voltage which is understandable but once the vehicle starts the battery continues to lose voltage. I've seen it drop all the way to 6V. I've had it at 3 different dealerships and they keep telling me the battery and alternator are fine. The battery was replaced once, they did a flash/update to the BPCM and most recently adjusted some pins in the BSCM
Heimkehr
Pennsylvania
2021 JLU 2.0T
I'm just spitballing here, but that sounds like a malfunctioning alternator forcing your vehicle's electrical system to function as Total Loss, as illustrated by the steep drop in battery voltage (which in isolation can permanently damage a battery that isn't designed for deep discharge & recharge cycles.) Possibly that's what compelled the battery replacement that's already occurred.
Has the alternator been separately tested for proper operation? By way of example, our chains, like Advance Auto, provides that service gratis. Perhaps Canadian Tire offers something similar to its customers.
Greco78
Greg
Canada
I'm not sure if it has. I'd like to think so but who knows nowadays. I'll have to quiz them about that and maybe look else where to get it done.
Greco78
Greg
Canada
Yes it is
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
Is it possible this is along the same issue with Teslas not charging when it’s wicked cold out?
Pape
Quebec
JLU Sahara
sound like the 48 to 12v is not doing it job when cold.
Would not be surprised as other mentioned that the 48Volts batt is just draining all the juice starving the rest when cold.
Greco78
Greg
Canada
Thanks for the info. I'll have to try and get the techs to inspect these options
Old Jeeper
Don
US Army Infantry, IT Engineer
X2 on that. I think you can stop off at some Auto Parts stores and they can do a test on your ALt on the vehicle.
The other option is to move South of the Mason Dixion Line...
Greco78
Greg
Canada
Update...
This weekend I learned if I start the vehicle with command start (FOB or App) it draws the battery down to a low voltage warning (11.5V or lower) and shuts off. Then I go start it manually it stays running and once the engine warms up the voltage goes back to 14V. This morning I decided to not use command start and start it manually and had no voltage drops. Is it safe to assume there's an issue with the command start?
