Speedometer
Jab16
Jillian
Porter
Jeep Wrangler Sport s JL
Is it normal for the digital speedometer to read different than non digital?
Jeep Wrangler JL Speedometer 1195D191-3E30-4DAF-B437-F209457887E6
XJfanatic
El Paso, Tx
2020 JLU, 2020 JT, 2000 TJ
Mine is off a mph or two. Think it’s a safety feature since they know we all speed. My digital speedo is dead on with gps speed though.
Ed Pursell
-Ed-
Lehigh Valley Pa, Allentown
2021 JL Willys- 3.6 Pentastar,8 speed Auto, Selec-Trac transfer case
Supervisor- MRO Buyer Maintenance- Pet food Mfg.-Now Retired.
My 2016 and my 2021 Willys is spot on, from what I see. When analog is showing 50, digital is showing 50. Let’s see what others post. But mine seems right on..
631_Islander
Area Code 631, NY
2020 Unlimited Rubicon with 8 speed and 3.6L Pentastar without eTorque.
Business Development Manager for the US arm of major global Fortune 500 Japanese Electronic Components manufacturer headquartered in Osaka, Japan.
2020 JLUR (100% factory stock). My digital and analog speedometers are usually giving similar readings and off usually by maybe 1 or 2 mph. Did OP get any mods done?
Jab16
Jillian
Porter
Ye
[/QUOTE
yes, I have a 3in lift with 37x22r
631_Islander
Area Code 631, NY
Ye
Ok. You may need to have your speedometer recaliibrated. Best bet is to go to the guy who did your lift and installed 37s for you.
jludave
The Isle of Long
IT Manager
XJfanatic
El Paso, Tx
Maybe so but this has been pretty consistent in the vehicles I have owned and large amount of rental vehicles. Though it could be vantage point/viewing angle of the analog.
jludave
The Isle of Long
IT Manager
There isn't a vehicle manufacturer out there that would purposely have the speedometer (analog or digital) show that you are not going your true speed.
Reinen
2021 Jeep Wrangler JL Rubicon
Not true. Nearly all speedometers are designed to err on the high side so they never show below your true speed. Manufacturers have no problem with showing slightly higher than your true speed.
TimmH
Timm
2018 JL Wrangler Sahara 3.6 Auto
Mine don't match all the time. It seems to start with 1mph more on the analog, and over the period of several starts increases to about 8-9mph (Was at 8mph diff today), then it suddenly goes back to being the same, and the process repeats.
It's been reported by several people over the last couple years.
But my digital always matches the GPS speed on my dashcam, and my phone when I've compared them.
CJ7 and 4 wheel drive
Gary
2020 Wrangler Rubicon
You may ve experiance parralax. If you look at the analogue meter needle at an angle, it will look like it is not showing the correct speed. Look at it straight on you should see a different speed.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
It will read correctly for the passenger.
Mine read about the same, +/-1 mph. I assume both the analog and digital displays receive the VSS from the same source. Looks like the needle on the analog gauge was not clocked correctly.
en2coasty
Tom
TX
2018 JLU Sport 2002 tj
Mine was off 5mph today, reset by using remote start......crazy
