Tynewlon
- Tyler šŗ
- Aug 19, 2021
- Thornton, CO
- 2020 JLU 2.0 4Cyl
Thank you!! This is definitely very helpful!! I think Iām going to join some local groups and see if I can find someone willing to help out. Iām willing to wait on getting it done so thereās no rush. Iāve got the LCAs because Iāve read that they make it ride better. But you are happy with the ride without them?Literally just put the Teraflex 1.5" spacer kit on my Jeep last weekend. If [like me] you're not going to be doing extreme rock crawling/flexing and just needed a little more clearance, it's a great kit. I purposefully only wanted ~1-2" of lift, due to the height of my garage and the height of my wife, so any of the other full suspension kits wouldn't have worked for me.
A few tips:
1. I didn't do the LCAs and it actually rides better lifted. Holds the line better on the freeway at speed, IMO. '21 Sahara Altitude, so not sure if the trim affected it.
2. Measure your corners before you order. Mine were 37" floor to fender all around - no factory rake at all. The Teraflex kit assumes you have a rake - it's 2" for the front, 1.5" for the back. They sell an additional 0.5" kit (you can buy fronts only, rear only, or all four) to level things out. I needed the 0.5" in the rear to level it out. They stack just fine. If I'd had both to put in at the same time, I'd have saved myself 3 days of driving around with a half inch squat and an hour's worth of taking the springs out again.
3. You do NOT need an alignment afterwards. With this kit (again, minus the LCAs, which IMO you don't need anyways) you're not touching anything that would impact your alignment.
4. For $800, I'd highly recommend that you just go buy the tools you need. Join a local Jeep club and make friends - it's more fun to do it yourself, you'll learn more about your rig, and this is STUPID easy to do on your own.
PARTS YOU'LL NEED:
1. Floor jack
2. Jack stands
3. Torque Wrench
4. Needlenose pliers (medium)
5. A good socket set. I believe you only need 10mm, 13mm, 15mm, 18mm, and 21mm. Oh, and 22mm for the lugs.
6. 18mm open-ended wrench. Bonus if it's got a ratchet on the closed end, but not necessary.
7. 14mm socket and 17mm open-ended wrench for the back spacer bolt. It's a *pain* so you're going to want another set of hands.
8. Spring for an impact driver. They're stupid cheap right now for the holidays and it'll make this job a million times easier. Plus it'll allow you to do your own tire rotations in the future.
This video is a good walkthrough. You do NOT need to have a floor lift and pole jacks. Just use the jack stands to hold the frame up and then use the floor jack to lower/raise the axles.
