Lift install cost
Tx_Wrangler
Geoff
Central Texas
2024 Wrangler Rubicon
I am looking for a cost of a 2" Mopar lift at the dealership. Parts provided by owner.
Trying to see how close my dealer is to the average.
Thanks
jadmt
jeff
montana
dealership probably will charge $1000 give or take, maybe more because you are supplying the parts. On a new jeep a simple mopar or AEV lift install I would do it for you for $500 on a new jeep that was not all rusty.....
Zandcwhite
Zach
Patterson, ca
2019 jlur
You already over paid for the lift, why not over pay for the install too? Not that the lift is bad, but it's incomplete for the cost of it. And I'm going to guess the dealer wants $1500 for the install?
Jad4275
Jeremy
Nederland, TX
2024 Wrangler Sahara
Dealership in AZ wanted $1400 for install. I opted to do it myself. If installed correctly no other parts are needed.
6.2Blazer
Ohio
2019 JL Sport
Looking at what is involved in that kit I initially guessed 3 hours max. Then found some references on line where they estimated 3-4 hours install time. I'm not a professional mechanic but have a decent amount of experience working on vehicles, have power tools, but no hoist. Installed Rubicon springs and shocks on a JL in about hour. That 2" Mopar kit has some additional work including front lower control arms, swaybar links, and I believe bumpstop spacers. When I did the install that included the swaybar links half unbolted anyway (to allow the axle to droop more). So the kit would involve an additional 4 bolts for the swaybar links, the front lower controls, and the bumpstop spacers. Assuming nothing was rusty and all the bolts came out easily, I can't imagine those items taking more than another hour or so.
SBLACK502
Charlestown, IN
2021 Jeep Wrangler
Do it yourself. It’s extremely easy.. used the save money for other stuff.
Jad4275
Jeremy
Nederland, TX
Agree. If you have the tools and jacks can do it yourself. I’m not the quickest and was able to do it in about 8 hours. I’m sure others have done it faster.
Jad4275
Jeremy
Nederland, TX
There’s a good video on YouTube:
Zandcwhite
Zach
Patterson, ca
2019 jlur
That's sort of true. The kit does nothing to address the track bars and/or centering the axles under the Jeep. The rear is cheap enough to just add a raised track bar bracket at the axle. ~$100 and the axle is centered and the roll center is improved, all positives. The front isn't as easy/cheap because you can't just raise the track bar mount or the steering will be screwed. You'll need to add an adjustable track bar so there's another ~$200. That's why I say that kit is incomplete for its cost.
Blues Fan 30
St. Louis
Yep my spacer lift took probably about 10 hours because a) I'd never done it before and b) retorquing the bolts took me probably 3 hours because I had to use to stupid jack to retorque the control arms bolts.
With proper ugga dugga tools could easily be a 2-3 hour job.
ColonelSanders
23 JLUR 4xe
I’m not going to say it’s easy for someone not mechanically inclined to install a lift, nor safe due to possibly using a spring compressor and multiple jacks. I did mine because I can’t earn $1500 in a weekend, and I’m not a mechanic. I do change my own hoses, belts, pumps, alternators.. I took it to a 4x4 shop a week after and asked they check my torques and such which cost $300.
