SOT owners - question?
kah.mun.rah
Merenkahre Jr.
Duat
There's one significant reason to leave it open in the garage. They have moving parts and motors that wear out. Like anything relatively delicate and mechanical, there's a limited number of times you can use it before it breaks. It'll cost ~$1.5k to ~$4.k if that failure isn't covered by your warranty.
Ours cost $1.5k to initially fix. The dealership "fixed" it, but it was much worse when we got it back. They basically had to replace the whole thing and wanted to charge an additional $3k. It took lots and lots of emails (so everything was recorded) to finally get them to cave and pay for it themselves.
On the flip side, moving parts need to move once in awhile to keep them lubricated and fabric needs to stretch out once in awhile to prevent the creases from becoming permanent and brittle at the crease. If it is kept open at home but closed while at work or the mall parking lot, maybe that is the compromise.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Was it just the motor that failed? How many years of use did you get from it before it failed?
Hell, I can't keep track of what all failed. They pretty much changed out everything except for the motor and cloth.
Bulletbill
Tom
Central PA
2021 JLUR
Look up at all the crossbars….. just one broken Plastic track end a $1.7K repair
Max Care covered minus deductible
That’s crazy. It would be great if there was an aftermarket option for repairing broken pieces, especially because it’s a fairly common option on a lot of Jeeps out there anymore.
2nd 392
Ca
1 cross bar 2 bar section, one on the track the other folds up. But the top has to be removed and partially disassembled to weave the new one in. Mostly labor
Jeep Wrangler JL SOT owners - question? IMG_2466
