alphawolff
- Jul 31, 2023
- california
- 2021 JLU
I have owned and driven multiple PUG 3.6L engines. The 89 makes a massive difference in the summer. You can *physically* feel the engine retarding timing. I really can't put it into words any other way, but I promise you it is a big difference. If you're not aware of what engine timing variation feels like then you probably wouldn't notice. We're talking maybe a 10-20 HP difference or something during an event like this, so I suspect you're right and that most people just won't notice it. They're Jeeps not racecars. It doesn't add power, it just prevents it from losing power during certain situations such as high ambient temperatures and high load.Curious as to the data that brought you to this conclusion - the people who designed the engine disagree.
I, and many others, have seen zero power difference running 87 octane. We have also seen zero gain in fuel efficiency. Note that the factory HP and torque ratings were established on its recommended fuel grade (87). So essentially you are claiming that you see higher than rated HP on higher octane fuel...which is not somethin that's been found to be typical.
Don't assume that your experience is the same as others, nor that your experience is the most common.
