93 Octane! I like it!
  1. PizzaFreak
    PizzaFreak Well-Known Member
    First Name:
    Vehicle(s):
    2018 Ocean Blue 2 door JL
    Jul 30, 2018
    Indiana
    63
    Liked:
    My new Jeep has around 1500 miles on it so far. My first fill ,Costco had the 93 for the same price as the 87. So I thought why not. It was the same on the next fill. I guess I got used to it because I tried the 87 for one fill and hated it. I thought the difference in the way the Jeep ran was huge. I have run 93 ever since. Anyone else experience this, or am I just imagining it?
    McBeeve and See Through like this.
  2. RubiZ
    RubiZ Well-Known Member
    Vehicle(s):
    2019 JLUR
    Oct 10, 2018
    Canada
    229
    Liked:
    162
    I noticed that mine runs smoother with 91 for sure. Never tried 93 yet
    2003hummerh2 likes this.
  3. MORTON
    MORTON Well-Known Member
    Vehicle(s):
    JLU
    Nov 11, 2018
    1,469
    Liked:
    1,516
    Garage Profiles:
  4. DougJaneway
    DougJaneway Well-Known Member
    First Name:
    Doug Janeway
    Vehicle(s):
    2018 JLU Sport S
    Jul 10, 2018
    Chattanooga, TN
    Liked:
    xeon likes this.
  5. Pic18
    Pic18 Well-Known Member
    Vehicle(s):
    2018 Mojito JLUR, 2017 Grand Cherokee Trailhawk (my wife’s)
    Jan 19, 2018
    RI
    355
    Liked:
    470
    Is this the 4 or 6 cyl?
    JohnAinVA likes this.
  6. Litfuse
    Litfuse Well-Known Member
    Vehicle(s):
    2018 JLR, 2017 Audi Q5, 2016 Ram, 2017 CBR1000rr
    Jul 18, 2018
    Columbia, IL
    591
    Liked:
    439
    This can be an issue with the turbo 4 but not the 3.6. The 3.6 can run on pee and vinegar.
  7. WXman
    WXman Well-Known Member
    Vehicle(s):
    2018 Wrangler Unlimited
    Mar 1, 2017
    Central Kentucky
    2,026
    Liked:
    1,485
    Occupation:
    The 3.6L loves higher octane too. Over the past five years and three 3.6L engines in three separate FCA vehicles, I've seen good results in smoothness, power, and fuel efficiency with higher octane fuels. Today's smarter ECUs will adjust VVT and take advantage of whatever you put in the tank.
    In short: Just because the Pentastar will run fine on 87, that doesn't mean that it won't run better on 91 or 93.
  8. Litfuse
    Vehicle(s):
    Jul 18, 2018
    Columbia, IL
    591
    Liked:
    439
    You would need to see datalogs to truly see what is going on. The buttdyno is not good enough.
    Majestic, ads75, misanthrope and 5 others like this.
  9. xeon
    xeon Well-Known Member
    First Name:
    Vehicle(s):
    JLU Rubicon
    Jan 18, 2018
    226
    Liked:
    145
    Over the past 22K miles in my JLUR i have found that I average 2 to 2.5 miles per gallon better fuel economy than if I run 93 vs 87. After a dealer tune up at 20K miles....the results are slightly lower...1.8 to 2.2 but still better. However the responsiveness, especially in cold weather is far better. So for me it depends on the cost of fuel that day. Quick math if 87 is $3.25 and I get 16 miles /gal. = $0.2 and if 93 is at $3.50 this would yield $0.19 so better to get 93 as long as the cost/mile is less. For me the other benefits would even have me go a bit beyond the equal point but the starting price of fuel can make a difference. When gas is more expensive the cost of using 93 is even better. Its not until gas prices are low that 87 wins out...but here in CA I haven't seen prices that low in a long time.
    WXman, Bandana and MORTON like this.
  10. Jeepmarkjl
    Jeepmarkjl Well-Known Member
    First Name:
    Vehicle(s):
    2018 Wrangler JLU Rubicon
    Apr 2, 2018
    Chicago
    501
    Liked:
    789
    Occupation:
    Marketing
    I did the exact same thing. 93 octane (Costco) engine seems to perform better. Not sure if that true but I’ll roll
  11. zgn
    zgn Well-Known Member
    Vehicle(s):
    Wrangler TJ (2001)
    Jul 16, 2017
    Maryland
    745
    Liked:
    388
    The manual explicitly says "there is no performance benefit to using a higher octane than 87." It doesn't say "it will run fine on 87", it says there is absolutely no point in using higher octane than 87 cause the engine cannot utilize it.
    JeepU4IA, ChattVol, Majestic and 6 others like this.
  12. nerubi
    nerubi Well-Known Member
    First Name:
    Vehicle(s):
    2019 JLR, 2012 JKU Sahara, 2018 Camaro SS, 2017 Schwinn 700c, SOVRN Geri
    Nov 28, 2018
    Nebraska
    895
    Liked:
    799
    Garage Profiles:
    Give up trying to convince some people that they are getting more power or better mpg with higher octane for the 3.6 or the people with the 2.0 getting same power and mileage on 87 instead of 91/93. They think without controlled conditions to accurately determine those factors they can tell the difference. Their butts have degrees in engineering.
  13. wv18jl
    wv18jl Well-Known Member
    Vehicle(s):
    2018 JL
    Nov 11, 2018
    WV
    71
    Liked:
    53
    15% increase in mileage with higher octane?
    In a 4 door with oversized tires?
    It's a miracle.
    eugene likes this.
  14. Litfuse
    Vehicle(s):
    Jul 18, 2018
    Columbia, IL
    591
    Liked:
    439
    Lol. I have a doctorate in buttdynoist.
    I have tuned myself or worked with a licensed tuner to tune my vehicles many times. You can think your car is running great or “better” and then you look at the logs and you realize your wrong. One car for example kept pulling timing and reducing power on the top end. I thought it was gas quality. It ended up being false knock created by a bolt on my exhaust that radiated through my exhaust and triggered a sensor. There isn’t a person on this forum that could sense that.
    And don’t start comparing gas mileage by 1-1.5 miles. That can be a factor of wind, temperature. Too many factors to list.
    Are there any engine tuners in here that want to share a word?
    2003hummerh2 and word302 like this.
  15. Jeepmarkjl
    First Name:
    Vehicle(s):
    Apr 2, 2018
    Chicago
    501
    Liked:
    789
    Occupation:
    Marketing
    I dont think I have more power with 93.
    It just feels smoother and the rattle hiccup quick cough on acceleration is gone.
    Now... my brakes are squeaking with only 6000 miles on them so thats a different story.
Loading...
Share This Page
