snorkel choices
wanderer
Ralph
Carlsbad CA
Engineering Geologist
looking for choices that run outside of the hood line for a 3.6 motor
arb
mopar
otherss?
If you are running any of these or something similar, please post some pictures and let me know how it attaches to the jeep. Thanks.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I run a cheap snorkel I purchased from Amazon $109. They cost a little more now. There's no way I was going to chop a permanent hole in my hood. (To each their own) This style snorkel can easily be removed and go right back to stock. It comes with both low profile and raised attachments.
Something to consider. Best of luck to you. 👍
Jeep Wrangler JL snorkel choices snorkel38
Jeep Wrangler JL snorkel choices snorkel99
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
aFe Dynamic Air Scoop
Jeep Wrangler JL snorkel choices 20251119_170200
Phantom01231
Richard
Houston
2020 Jeep Wrangler Unlimited Rubicon Recon
How is the fit and finish on the Amazon knock off? Body lines match up ok? Heard one person say theirs got warped from heat…
Flip
Johnny
Virginia
1st photo: This piece could have lined up a little better. It's not noticeable unless you eyeball it closely. 2nd photo: Some people said this piece was sagging in the middle from heat. Mine was doing ok but it seemed susceptible to this so I added the extra spacer in the center. There was a discussion on this and a gentleman was making a spacer for these on his 3D printer.
Jeep Wrangler JL snorkel choices 791053-48eac4f735bda31af7966f953ca0418d
Jeep Wrangler JL snorkel choices 791052-011c4273caea563191561308887b6cb2
Alonso.ees
Alonso
Vancouver
2019 Jeep Wrangler Rubicon Unlimited
Hey man! How long have you been using that kit?
Is it a good option?
Alonso.ees
Alonso
Vancouver
Hey there!
I’m planning to get that snorkel, but I would like to hear some comments about it, what do yo think of it?
how’s the water accumulation in the filter box?
Flip
Johnny
Virginia
I installed this as a means of cooler air. The difference was only about 2 or 3 degrees. It was very inexpensive when I bought it. ($109) I noticed they have more than doubled in price. The kit overall is ok. The alignment was slightly off on the low profile snorkel. The plastic on the long tube is thin. They are known to sag in the center as heat builds under the hood. I installed the high rise extension one time. It seemed unstable to me. I thought for sure it was going to blow away on the interstate but it held on.
I went back to the low profile snorkel. I have no intentions of going into water that deep. I don't get any water in the air box unless I forget and spray the hose at it when I'm washing my jeep. There is a drain line & valve just in case.
Alonso.ees
Alonso
Vancouver
Hey thanks a lot for your comments!! Cheers man!
deepseaballee
Austin
Alaska
2020 JLU
How much space is there between the snorkel and the battery? I have some aux switches and the box for the aux switches sits right over the battery.
Flip
Johnny
Virginia
Not much, it's pretty tight. Off the top of head and don't hold me to this......maybe 1/2 - 3/4 inch.
I can get a closer measurement tomorrow for ya.
