ivo
Are you still using the non animation version? I have the same brand bought way before any option for non animated were available.P.S. I bought a set of these on Amazon. Way less expensive and look exactly the same. The only difference is this version says it doesn't have the "chase effect" when unlocking the doors etc. So I'm hoping since it doesn't have the chase effect built in in the first place, maybe it'll never be a problem.
They should be arriving today. I'll test them out for a while, see how they do and ill post back here again.
Here's the link. Make sure you buy the ones without the chase effect because when you check out they have like four different options and one of the options is chase effect, or "welcome lights" or something like that.
VLAND LED Tail lights Compatible with Jeep Wrangler JL JLU 2018 2019 2020 Sport, Sahara, Rubicon, Moab ( Not Fit JK) with Tunnel Light, Red Turn Signal Red Clear https://www.amazon.com/dp/B07XQL15SP/ref=cm_sw_r_em_apa_fabc_G0VM74Q9Z9CD2JP4484R
Mine started animating non stop 4 months after purchase. Luckily still have the OEM lights.
Judging by everyones feedback its the same time frame these lights started to not work something failed within. I could care less about the animation but would love these lights to work properly again as they're unique looking.
Has anyone tested these on a LED compatible JL?
