Shore Power - AC input
xeon
JLU Rubicon
Hi there,
Like many of you, I have had my issues with battery drain, replacing batteries, aux batteries, etc.. My JLUR is just not driven enough to keep the batteries charged. Its been recommended to use a battery tender but if I have to hook up AC power to the JEEP why not do some other things with it:
1. Charge my main and aux battery (power a tender)
2. Ability to keep my Goal Zero topped off
3. Ability to keep the drinks in the frig cold.
4. Convenience of not having to run multiple extension cords to the hood and side window to power things
So I am wondering if anyone has opted to put a shore power connector on the side of their JEEP and if so where and if so what did you use and what does it look like.
I thought it might be neat to use a 4xe charging door and put the port inside that so I didn't have this big typical RV-looking port stuck on the side of the jeep.
I am sure I could wire something up and leave it inside the cab but leaving the windows cracked out here in the desert is just inviting a bunch of dust and critters to be visiting the inside so hoping someone has done a great conversion out there.
If not, I might add another fuel door if my first idea doesn't work out....hmm.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
It’s defiantly a doable thing, although i don’t know if you could retrofit a 4xe cover easily to do it. They make shore power outlets for RVs and trailers that could be used but would be a permanent installation.
Just curious, have you considered a dual battery kit? Ours does well with minimal driving and keeps a fridge going 24x7
dpike
New Jersey
'20 JLUR 3.6
someone did this with the 4Xe cover. i think they posted in it in the what did you do TO your jeep thread, my guess would be 3 or 4 months back.
Reinen
2021 Jeep Wrangler JL Rubicon
Definitely doable but the 4xe port may be difficult to convert as it's a completely different plug. Look into marine thru-hull connectors for a generic solution.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Ha, as I read your post my first thought was 4xe charge port. Someone used one to install an air hookup if you can find one.
Another though, that’s likely easier and cheaper, tons of stock trucks that tuck a female plug at the grill for block heaters.
rkwfxd
Rich
Whittier
Unemployed
FWIW
I ordered my Rubicon with the tow package. I wired a Battery Tender into a trailer style tow plug and just plug into my factory receptacle. Works great to keep the main and aux batteries topped off and I don't have any extra wires or plugs hanging down.
One could probably do something similar to power multiple items while parked.
LanceMagnum
New England
2020 JLUR
Passenger rear quarter:
Jeep Wrangler JL Shore Power - AC input 1655942280064
Runs to a power strip in the cargo area, with one outlet to a Redarc BCDC that charges my house battery:
Jeep Wrangler JL Shore Power - AC input 1655942460148
jessedacri
Jesse
Lake Arrowhead, CA
2019 Bright White 2dr JL Rubicon 3.6
I think it'd be a matter of using the location and factory door, removing the 4xe plug entirely inside and mounting the shore power plug inside.
OSCAR II
NJ
14 JKF
Was thinking the same thing but its a male plug behind the door, which is what you want.
zrickety
Technician
Some great ideas in here, thanks for posting.
xeon
xeon
JLU Rubicon
thank you all for your great replies. Lots of great ideas. The 4XE charge door and stuff are a bit pricy but I think it will look the best and be convenient for what i need. Going to give it a shot at least. Thank you all again for the great information.
GATORB8
CLT NC
Lol, yes. Must have been thinking a male plug that identified as female.
