Shock Talk ( Shock Info / Spreadsheet)
AllJumpStyle
CA
JL
Isn’t the synergy spring dual rate? A ride rate and a flex rate? I wonder if the 3” synergy shocks would work with the 4.5-6” shocks? @AllJumpStyle sorry to tag but any input?
Yes, our springs have a primary rate and a softer initial rate to allow for more spring travel and a longer extended length. Both our 2" and 3" springs are set up for shock lengths similar to Fox's 3.5-4" lift shocks. If you are ok adding more bump stop spacing, longer shocks can be used, but you will quickly run into other issues from the increased droop that need to be addressed.
RubiRob
RubiRob
Rob
Hampshire, IL
www.instagram.com
24 F-150 Raptor
Janitor
Ok thanks for the info!
Roky
Roky
Added Accutune's custom Fox 2.0RR (they're different from the Fox Performance JL specific 2.0 RR)
I don’t see rk RRD 2.25 on you’re list. The 3.5” lift shocks are 29.3 extended front 30.3 extended rear. 11.5” travel front 12”!travel rear. In case you want to add them.
RubiRob
RubiRob
Rob
Hampshire, IL
www.instagram.com
24 F-150 Raptor
Janitor
They’re on there but I have them on the next page with all the other 2.5-3.5ish shocks
