SGW Extension Cable Toggle
AndySpill
Andy
Pittsburgh
2018 JL Sahara
I'm very glad I have an SGW Extension Cable.
Physically disconnecting my JL Tazer before a dealer service is so much easier with it installed than not.
But you know what would even be cooler--if doable, if someone developed a "Y" cable with a toggle switch such that the factory cables would plug into the "vertical portion of the "Y" and the angled portion of the "Y" would plug into both the JL Tazer and SGW Gateway.
A mutually exclusive toggle switch in the vertical portion of the "Y," just before it diverges, could then control where the factory cable signals end up: at the JL Tazer or the SGW Gateway: always exactly at one of these two.
This way, unmarry the JL Tazer, flip the toggle and be done. Plug in the JL Tazer once in your ownership. Never futz with getting those connectors free--much as the existing extension cable makes accessing them loads easier than without the extension cable.
Sure, that toggle switch would have to independently reroute, what, about 20 independent wires....but it's doable.
My $0.02.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
20-ish critical wires being reliably switched by 20-ish connections in somewhat extreme environments, switching in/out something that is already known to be a bit flakey?
Terrymo
Terry
2023 JLURXR 3.6 ET
I like theoretical projects like this, but I’m wondering how many service appointments you have that would make this worth it. Seems like other than the challenge of building a prototype the juice may not be worth the squeeze. But looking forward to seeing what you come up with.
