SGW 12+8 - Need help locating these connectors.
xj2jk2jlu
NY
2023 JLURXR 3.6 eTorque
Hello! Need some help locating these connectors. Does anyone know the name of these 12 & 8 pin connectors?
Jeep Wrangler JL SGW 12+8 - Need help locating these connectors. IMG_0156
I’m looking to create a harness like this one:
Jeep Wrangler JL SGW 12+8 - Need help locating these connectors. IMG_0144
This harness was created by @dayusmc and is for a Tazer mini.
xj2jk2jlu
xj2jk2jlu
NY
No. It’s part of that, but the other side coverts to canbus and power +\-
Grayhound
Michigan
Jlurd
What is the advantage of being plugged in to the canbus directly?
xj2jk2jlu
xj2jk2jlu
NY
For security purposes. I use the Tazer specifically for the canbus immobilizer / PIN. Using this harness you’re able to hide the Tazer anywhere in the vehicle so it can’t be easily removed by a thief.
bmpcamry09
Rock Sponsor (Level 1)
New Athens, IL
2025 JLU Sport S 3.6 8AT
About 7 minutes in to my YouTube video here you’ll see where to go with it. Only difference is my install was inline.
You can’t mess it up. Both connectors are different and none of those connectors work in any other place.
xj2jk2jlu
xj2jk2jlu
NY
I know how to install / bypass the SGW. I’m looking for the name of the connectors circled in my first photo above. I need to make a custom 12+8 pin harness like the one in the second photo.
bmpcamry09
New Athens, IL
I know how to install / bypass the SGW. I looking for the name of the connectors circled in my first photo above. I need to make a custom 12+8 pin harness like the one in the second photo.
Well then what do you mean name? They are the security gateway module connectors. Are you looking for a connector part number? You’ll be better off finding any junkyard Mopar from 2018 and newer and just cut one out.
xj2jk2jlu
xj2jk2jlu
NY
There’s gotta be a way to just order the connectors so I can pin it myself. If not, I’ll order the extension and remove the wires. I was just looking for a cheaper solution.
xj2jk2jlu
xj2jk2jlu
NY
Jeep Wrangler JL SGW 12+8 - Need help locating these connectors. IMG_0158
Looking for these empty connectors.
bmpcamry09
New Athens, IL
I can’t track down those part numbers. But every 2018 and newer Stellantis product will have the same ones at the SGW module in a junk yard.
xj2jk2jlu
xj2jk2jlu
NY
Thanks for trying! I think it will just be easier to order the SGW extension and double bypass from Zautomotive
xj2jk2jlu
xj2jk2jlu
NY
Got it!! Thank you!
