Service 4WD
jlroman2
Jorge
Chicago, IL
2018 Jeep Wrangler JLU Sahara (Granite)
BCBA
Has anyone gotten this light on the dash? I got my lift and new set of 35s installed today and when I picked it up it gave me this light on the dash. I also have the flashcal superchips programmer and was wondering if this can be fixed using that?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Too much of a coincidence here. Is it possible that the front locker harness connector wasn't plugged back in after the install?
jlroman2
jlroman2
Jorge
Chicago, IL
BCBA
Most likely something like that happened. Going back to the shop tomorrow and see whatā€™s up.
jlroman2
jlroman2
Jorge
Chicago, IL
BCBA
Any clue where this connects? Lol
jlroman2
jlroman2
Jorge
Chicago, IL
BCBA
Thanks yaā€™ll. Iā€™m clearly blind af
jlroman2
jlroman2
Jorge
Chicago, IL
BCBA
So yeah. This got rid of the service 4WD light. Iā€™m still taking it to the shop tho because it feels like if something is hitting when I apply the break and slow down or when itā€™s moving at low speeds.
mikehabl
Bothell, WA
2019 JLUR
I had the same warning light come on and took it into the dealer.
Their shop notes said:" Verified there is a code DTCM C-147B-14, 'Front axle disconnect sensor-short to ground or open'. Found STAR publication about this code to check for water in connector XY460A. I found corrosion on 4 of the pins and connectors. Cleaned pins and insulated with dielectric grease. Retest system, working as designed, no codes reset."
I haven't had any issues since.
Az-jewel
Julie
Southern Utah
aquajeepgirl.com
ā€˜18 JLU Sport S
SAHM
was your light on all the time? Iā€™m getting the serv4wd light but only when Iā€™m in 4WD for a bit. It doesnā€™t stay on after itā€™s back in 2hi and restarted, and I couldnā€™t get a code on the reader.
mikehabl
Bothell, WA
2019 JLUR
It was a bit sporadic on mine as well. If I took it out of 4wd for a bit it would clear. Then if I put it back into 4wd, it would light up again after a short time.
Az-jewel
Julie
Southern Utah
aquajeepgirl.com
ā€˜18 JLU Sport S
SAHM
Thank you!
it was the FAD, the gasket needed to be replaced and the actuator was mistakenly put inside the axle collar when the shop reassembled it after my regear. Itā€™s been fixed and works well now!
