Sag when installing bumper and winch on 4XE?
TeeGeeThree
Tim
New Jersey
Jeep Wrangler Sahara 4XE 2021
I'm planning to add a front bumper and winch to my Sahara 4xE. I'll be running Rubicon KO2 takeoffs, eventually. The bumper I'm looking at is around 80lbs, and the winch is 67 lbs. I've heard the 4XE has upgraded springs, to deal with the battery weight. So...
Any guesses as to what kind of sag I'll be dealing with, and whether I'll need or want spacers? I'd love to avoid it if I can, just one less thing to deal with.
dpike
New Jersey
'20 JLUR 3.6
i didn't notice any real sag with the steel bumper and winch or sliders on my jlur until i put the rack and rtt on it.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Personally I think all Wranglers look better leveled even before adding weight to the front. If I weren't going to lift my jeep (good luck with that), I'd run a 3/4" spacer up front. You'll probably only sag 1/4"-1/2" from the winch/ bumper combo so it's up to you how leveled you want the jeep to look.
RDakota
Roger
2021 JLURD
Someone said last week to put the same weight on the current bumper that would be the net increase and then measure the sag. I thought it was a great idea.
TeeGeeThree
Tim
New Jersey
Any idea how much weight I’ll be losing by removing the current plastic Sahara 4xe bumper?
RDakota
Roger
2021 JLURD
I’ve heard 35 lbs for the whole thing. At least that’s what I’m planning on until I hear a better number. I think it makes a difference if it’s a Rubicon or not.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Sounds about right. Shouldn't be any real weight difference between the trims. Negligible at best.
Grimmjpr
Salt Lake City, UT
2024 JLUR 392
After I installed my Badlands Apex 12k and Grimm off road winch plate, on the factory steel bumper, it looked like I didn't lose much of any, but after a trip to Moab it settled about half an inch. I put on a Teraflex 1/2 inch front spacer to get it back to where it was originally. This is on a 21 Rubicon 4xe.
TeeGeeThree
Tim
New Jersey
I think the suspension is different on a Sahara 4xe and a rubi 4xe…? Maybe?
Zandcwhite
Zach
Patterson, ca
2019 jlur
The suspension on the Rubicon generally sits 1" taller, but the spring rates are similar enough it should be relatable. I'd guesstimate you'll want a .5-.75" spacer unless you prefer more rake than factory. It isn't necessary, people run winches and the slight sag for years. It's purely cosmetic preferences.
Mgg253
2021 JLUR 4xe
I just installed the apex badlands 12k with rockhard winch plate on my steel bumper. Sags .75” in the front now… rough country .75” front coil spacer on order now
Before
Jeep Wrangler JL Sag when installing bumper and winch on 4XE? DD80481D-BA44-4371-8419-CD8864E651D9
After
Jeep Wrangler JL Sag when installing bumper and winch on 4XE? FB86110C-47DC-4422-BBFE-A3D951726D98
