Ratbert
You have to replace the whole axle???on Jeeps, if you rip a CV boot you have to replace the whole axle. No such problems with the simple ujoint thats fully serviceable.
yes , the whole axle shaft. Not the axle housing. You can’t just buy a replacement CV boot.You have to replace the whole axle???
Every JL and JT has the FAD. 4 auto is irrelevant.The only potential issues I've heard mentioned on the 4-auto equipped Jeeps is the FAD (front axle disconnect) being a weak point in the front axle. But you can do a FAD delete if you wanted.
You mean 2 piece axle, not FAD?Every JL and JT has the FAD. 4 auto is irrelevant.
All 2024's have cv style axles fyiAlso the 4 auto has rubber CV brackets and the non auto has beefy U-brackets. Both work, but I've heard the auto joints are more prone to catch a stick or rock and cause damage where the bulkier U-joint can tank a hit better.
That is incorrect they have done away with the fad on most of the 2024'sEvery JL and JT has the FAD. 4 auto is irrelevant.
Interesting, I wonder why the change, maybe to simplify the manufacturering orocess with just one option.All 2024's have cv style axles fyi
Tazer can force RWD on the auto Tcase which means you aren't wearing out the clutches needlessly.No, it's a completely different transfer case. A TAZER can't change the fact is uses wearable clutch plates (as opposed to gears) to lock the front and rear axles.
