Rubicon 4XE - Off Road Lighting ?
dstevens
CA
2024 JLURX
Is it a 2024? Because if you are bold you can be the first Jeep to have 120V lighting using the power box.
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
www.instagram.com
2025 JLU Rubicon (Anvil Gray)
Jbudz511
Josh
NJ
'21 JLU Sahara Altitude, '00 XJ Sport
I like the quadratec stealth bar. Mounts inside the cabin so not exposed to elements/no wind noise/ no drilling. Not exactly the cheapest i guess but works nicely.
Jeep Wrangler JL Rubicon 4XE - Off Road Lighting ? PXL_20231118_214958969
Jeep Wrangler JL Rubicon 4XE - Off Road Lighting ? PXL_20231118_215105625
Jeep Wrangler JL Rubicon 4XE - Off Road Lighting ? PXL_20231119_165704505
Jeep Wrangler JL Rubicon 4XE - Off Road Lighting ? PXL_20231119_165814674
leeshuming
Burnaby, BC Canada
2022 4xe Tuscadero
I suggest you get a new aftermarket 12V AGM battery first.
For the A pillar mount, a good option is the KC a pillar bracket, it clears the plugin charging port.
Or you can go full ham and get the KC pro 6 gravity light bar with the KC mounting bracket.. that is pretty much your option, unless you go to a Chinese website and find some.
Otherwise you will not find a good one that fits 4xes.
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
My KC Flex Era 4 just got the delivered yesterday along with their A-pillar mount. Back when I did a thorough research, I narrowed down to KC and Baja. Ended up ordering from KC. I am also planning on getting their 50 inch light bar at some point and FE 3 SAE lights to replace the stock fogs.
FLEX ERA® 4 - 2-Light Master Kit - FLEX ERA® 4 - 2-Light Master Kit (kchilites.com)
Bracket Set - Light Mount - Windshield - Pillar Mount - Pair - for 18-24 Jeep JL/JT/4xe - Bracket Set - Light Mount - Windshield - Pillar Mount - Pair - for 18-24 Jeep JL/JT/4xe (kchilites.com)
