Buckster
- Matt
- Jun 18, 2019
- Palmetto, FL
- '19 billet silver JLUR, '25 Volvo XC60
- Occupation
- Power Generation
- Vehicle Showcase
- 1
This.If I had to guess, I'd say the outer portion of the outside brake pad broke of. Visually inspect or swing the caliper and pull the pads.
Definitely no pad contact on the outer portion of the rotor. You should be able to get a decent visual just by pulling the wheel, but I'm betting that you will be replacing the pads. If the difference between the contact and non-contact area is minimal, you could probably get away with just "bedding" the new pads pretty hard. If it's been that way a while and the non-contact area has a defined lip, then you would likely need to get the rotor machined to even it out. Not sure who does that anymore though due to liability.
