Rock Light Suggestion
dbeacham15
dbeacham15
Daniel
Orlando, FL
2018 JLU Wrangler 4 Door - Mojito
I installed these because I’m a cheap a55. 8 pods for $130. No complaints so far. Super bright and can turn on and off with my aftermarket AUX buttons or with cell phone. Can change colors through Bluetooth on cell phone also
I like that Switch setup. I just went with the standard Mopar 4 switch one.
Yellowssm
Ray
Las vegas
JLUR
Yeah mine didn’t come with the factory ones and I wanted more than 4 so this was it. Only $250 so cheaper than factory ones and works great so far
jason0341
Jason
2020 2.0L Rubicon
I just installed some Lux rock lights. I need to move my fronts to shine down more. Maybe make a metal plate and attach that to the plastic inner fender wells. Other than super happy with them. Ordered on a Friday and received the following Friday.
Jeep Wrangler JL Rock Light Suggestion 4BA5426B-9145-4310-8100-A80BC90A6032
Jeep Wrangler JL Rock Light Suggestion 48BF2E48-0B68-42B9-A419-2A0F8006B0C3
A Sober Animal
Daniel
Chicago
2020 JLUR Recon
I installed these because I’m a cheap a55. 8 pods for $130. No complaints so far. Super bright and can turn on and off with my aftermarket AUX buttons or with cell phone. Can change colors through Bluetooth on cell phone also. Video at the end of pics
Two questions:
1) Is that the VOSwitch JL300? If so, did you install yourself? How difficult was that to wire? I have one sitting in a box that I may try to wire up this weekend.
2) Where did you mount the rock lights? Anything that had to be drilled or were you able to use existing holes?
Yellowssm
Ray
Las vegas
JLUR
Two questions:
yes voswitch jl300 but I had buddy install it for me because he’s done all my stereos/electrical for years. He also installed rock lights. 1 in each wheel well, one by each slider, one front and rear bumper
A Sober Animal
Daniel
Chicago
2020 JLUR Recon
Did that involve any sort of drilling or were you able to using any pre-existing holes/mount areas?
spurly
Zach
Nebraska
2019 Bright White JLUR
8 KC Hilites Cyclones
Jeep Wrangler JL Rock Light Suggestion 20201128_193639
Jeep Wrangler JL Rock Light Suggestion 20201128_193302
aham23
A
Arizona
2021 JLU Rubicon
Nice. Can you describe where and how you mounted them. I’m not seeing a lot of great options in the plastic wheel / fender liners.
spurly
Zach
Nebraska
I
I'll take some better pictures when I get home later. But here's what I have.
For the front pair, I used a fender mounting bolt. I had to use a 5/8th steel spacer so it would sit level and wasn't sitting against the liner. For the 2 on each side, I used the included Z brackets and mounted the forward and rearward most mounting bolts for the rock rails. The rears are mounted with the included L bracket up against the frame where the factory bumper bracket bolts to.
Jeep Wrangler JL Rock Light Suggestion 20201128_194436
Jeep Wrangler JL Rock Light Suggestion 20201128_194444
Jeep Wrangler JL Rock Light Suggestion 20201128_194451
Jeep Wrangler JL Rock Light Suggestion 20201128_194510
aham23
A
Arizona
2021 JLU Rubicon
I
Big help. Much thanks!
Goin2drt
Kentucky
18 Rubicon, 17 Grand Cherokee Trailhawk
@Yellowssm can you give more details on those aux switches? Obviously aftermarket? Is it plug and play with the current aux switches from Jeep? Meaning if I got the aux switches from factory could I pop those out and just plug these in so I would have those cool lighted buttons and actual names for the things I have?
Thanks.
aham23
A
Arizona
2021 JLU Rubicon
General lighting questions; so many options I’m a bit confused on what I need.
Planning rock lights to help light up the desert camp sites and keep creepy crawlers at bay.
After that not sure. Building up a back country exploring and camping Jeep. Won’t be doing much in the way of night trails or runs. Maybe a few here and there. Not a rock crawler either.
Light bar? Ditch lights? Camp lights off the roof rack?
Much thanks.
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
We now offer True White LED Rock Lights from ORACLE Lighting. These are perfect if you are just looking for functional underbody lighting and are not interested in having color changing lights.
These are really great, using top-quality LED chips and are super bright!
Jeep Wrangler JL Rock Light Suggestion white_rock_lights_wheel_lights_oculus
