Martindfletcher
Yes spider traxLooking good, Im glad my 2-door will net a little more height. Are you running wheel spacers on those stock wheels? If so, which ones?
https://www.quadratec.com/p/spidertrax/1-34-wheel-spacer-jeep-grand-cherokee-wrangler-jlYes spider trax
If using a long travel shock without an offset, that is certainly a possibility. First verify that the axle is centered by adjusting the track bar as needed.Between the 3.5 height before a body is added, the shock hitting the frame at flex, and the rear trackbar danger close to exhaust, I'll be recommending MC from here on out, for sure.
I think so, I got them from Marcus at RCO. See his contact info above and give him a ring.
I also have a 37 rear tire, tailgate reinforcement, 80lb winch, now a high lift on the front bumper, and some some armor and boat load of tools in there. I do not have my measurements at work but it seemed I got the full 2.5".I mean would I be wrong if I said Martin's 2.5 on 37s looks the same if not MORE clearance in fenders than my 3.5 on 35s? The 3.5 on 35s should look ridiculously small. Hell, people even ask me if I'm running a 2.5 lift.
I know it's a bit of a stretch, but could you measure your spring from bottom of seat to lip of perch, like mine?Soooo..... I installed a 2.5” adventure kit. There was some mix up with the lower control arms, however Adam with Rock krawler took care of it ASAP and their customer service was awesome. I did order my kit from northridge 4x4 and had to wait a month even though it showed in stock on their website (pretty sure this is a common problem with them) I have been ordering from River City ever since and Marcus has been top notch. Now when I installed the RK kit I put an additional rough country spacer on, hoping for it to sit higher in the front than the rear ( my style I like that, not for everyone). I was sure glad I did, with the 3/4” spacer and the 2.5” kit it put me just shy from level at the bottom of the fenders. I may go back and order the 3.5” front springs to remove the spacer. I do not think using the same springs as the JK for the front was the best option as I would have liked it to level at the same time, but RK knows far more than me. The RK kit gave me exactly 2.5” and on the front 3.25” (with the spacer). I would say their kit is true to the height advertised. I went with the falcon shocks and 37x13.50 tires.![]()
You caught me in the garage, it measures at almost dead nuts 12.5”. Sahara with plastic bumper.I know it's a bit of a stretch, but could you measure your spring from bottom of seat to lip of perch, like mine?
