Rock Krawler 2.5?
MikeJLUR
Virginia
2019 4 door Rubicon
Question. It's been a few years since I looked at lifts. Rock Krawler used to have several 1.5 lift kits for the JKU.
Did you stop making these lifts for the JKU? Is there a reason why? Are there plans to make a 1.5 lift kits for the JLU?
Rock Krawler Suspension
Tech Support
Waterford New York
rockkrawler.com
Red JLUR, White JLUR, Yellow JL (3 so far), Bikini Diesel JLU, Billet JT, Hydro Blue JT
In the JKU, it was not a big seller, less than 10 units per year so it was dropped. We have talked about 1.5" JL/JLU kits but nothing final has been decided yet.
MikeJLUR
Virginia
2019 4 door Rubicon
Thank you for the reply. I had the RK 1.5 lift on my 2014 JKUR and loved it.
Engmoreau
Armando
West Palm Beach
Jeep JLRU
You just need to make sure you're buying JL specific spacers because of the longer wheel studs. They are universal between JL and Grand Cherokees since the bolt pattern and wheel studs are the same between them.
Synergy are 1 5/8 and Spidertrax are 1.75". Either of those will be plenty for stock wheels and tires or a stock wheel with a 12.50 or so on it.
Marcus
How much do you sell them for? Tire km3 37x12.5x17
word302
Oregon
JLU
No, other than less back spacing and mud flaps. Rockblokz makes great quick-release mud flaps. Takes about 2 minutes to remove them.
Arrowhead
George
Stillwater, NY
2018 Wrangler JL Sport
Got my 2.5" X factor installed. Replaced the Rubicon takeoff springs and shocks. Gained about 3" in front and 2" in the rear (the front was sagging about 1" from the bumper and winch with the Rubicon springs). Overall it's 3.5" taller than stock sport height. Sits perfect level like I wanted it, but it begs for 35's now.
Jeep Wrangler JL Rock Krawler 2.5? 7Luf8XJggq1MW7PZH_iTQKeg-8t3rWM8LnTUW6B4YKEpiBilyyAHQetP3MjlXYY6QqVovbWcFgKmw_HSqFQ=w873-h656-no
Tech Support
Waterford New York
rockkrawler.com
On a rubicon axle, you'll probably clear. I ran a wheel with 4.54 back space on 37x13.50's and cleared with a little room to spare. You'll be tight for sure, but I think it'll clear...
No promises though as every wheel manufacturer can be a little different.
rayzjeep
Ray
Melbourne, FL
2019 Jeep Wrangler Rubicon Unlimited
Aerospace Engineer
I have the 2.5" RK Adventure Series Lift with the front lower control arms and the RRD shocks. I thought the ride was a little stiffer than I was expecting to be honest. Tires are 37" Yokohama Geolander M/T G003's set at 30 PSI cold. Could it just be the tire since they're load range D instead of C? From my research the load range D at lower pressure should behave like a C. Any suggestions to help with the ride quality? I especially notice the difference over pot hole and railroad tracks when compared to the stock suspension.
CarterRuss
Russell
West
19 JLUR, 07 RS4
I'm no expert in this as this is my first Jeep but I have my D rated tires set at 26 cold (Toyo RTs).
Arrowhead
George
Stillwater, NY
I believe you can have RK revalve them for you
From their shock page:
  • (00) Zero valving or no shims;
  • (30) Light valving;
  • (40) Light-Medium valving;
  • (50) Medium valving;
  • (60) Medium-Firm valving;
  • (70) Firm valving;
  • (80) Extra Firm valving
  • (90) Hard valving
When ordering the first number is always your compression dampening and the second number is your rebound dampening! For example a 40/60 valved shock would be a shock that is Light-Medium in compression dampening and Medium-Firm in rebound dampening.
zmanz28
Zman
Minnesota
2018 Jeep Wrangler Sahara
7Luf8XJggq1MW7PZH_iTQKeg-8t3rWM8LnTUW6B4YKEpiBilyyAHQetP3MjlXYY6QqVovbWcFgKmw_HSqFQ=w873-h656-no.jpg
I'm doing the same as you, I'm going to be begging for 35's too. I'll live with it until I burn through my 33's.
