Rock Jock Torque Spec too low?
Il Commandante
Dirk
Northern Germany
2021 JLUR 2.0
Dear fellow Jeepers,
step by step more Rock Jock components found their way into my suspension setup. And now it's a complete Lift, except for the front JKS control arm relocation bracket, that is still in. However, while trying to hunt down a clanking sound, that is loud but only occurs now and then, I re-torqued everything according to the Rock Jock Lift Kit manual.
They recommend 40 ft.lbs for the front upper control arms, 75 ft.lbs for all rear arms, and so forth. This seems very low to me.
Does anyone of you have experience with the Rock Jock lift?
Or does anyone of you have an opinion on the low torque values?
Thank you for your input,
Dirk
Bill_BCNtoNY
NY
Ocean Blue JLU Sahara 3.6
Advisor to Boutique Consulting Firms and Solo Practitioners
That does seem low... I would call or email and ask them if they forgot a "1" in front of those numbers.
Then again, my opinion is not grounded on anything besides having installed my lift a few months back - I don't work or know enough about this to tell you those specs are impossible.
Maverick909
I.E.
thats way to low for the control arms. front arms are lower are 140 ft lbs uppers are like 50 ftlbs. when in doubt factory specs are best
fronts ft-lbs n-m
Upper control arm front nut | 55 + 185° | 41 + 185° | - |
Upper control arm rear bolt | 50 + 135° | 37 + 135° | - |
Lower control arm rear nut | 140 + 145° | 103 +50° | - |
Lower control arm front nut | 140 + 145° | 103 +50° | - |
rears ft-lbs n-m
Upper control arm front bolt | 100 + 80° | 74 + 80° | - |
Upper control arm rear nut | 100 + 65 ° | 74 + 65° | - |
Lower control arm front bolts | 100 + 50° | 74 + 50° | - |
Lower control arm rear nut | 100 + 50° | 74 + 50° | - |
https://www.jlwranglerforums.com/fo...for-jeep-jl-wrangler.17791/page-2#post-518105
Il Commandante
Il Commandante
Dirk
Northern Germany
2021 JLUR 2.0
fronts ft-lbs n-m
rears ft-lbs n-m
That’s what I thought. But then, Rock Jock seems to be a company that knows what they are doing.
Unlike myself: I have no clue what to do now ?
Will probably take Bills advice and write them.
Maverick909
I.E.
Every kit I’ve installed I always run factory spec.
Il Commandante
Il Commandante
Dirk
Northern Germany
2021 JLUR 2.0
Never had any issues?
I did it the same and used factory torque first. But I have this clanking sound once in a while, so I thought I try their spec.
Occasional clanking still there, no change….
Il Commandante
Il Commandante
Dirk
Northern Germany
2021 JLUR 2.0
The torque specs are easier to understand using the Mopar suspension install sheet.
I am literally now starting to re-torque everything, so this Information is most welcome! Thank you Victor! ??
