Right side front axle not dropping enough?
Remorseless
NC
Track bar not holding it, looks like the shock is still connected, probably just the pic…
Can't tell if the shock is connected either, hope it's off lol. But yeah, I don't think track bar is holding it, I'm thinking it's trying to shift axle to driver side but since the jack's on that side putting pressure it can't shift that way to continue down. Jack technically stopping it, but can remedy by pulling track bar off the axle bracket. Though, if the shocks are still connected, that'll do it too.
Roky
Roky
Yeah, needs the jack closer to drivers tire……
Eischman
Eischman
Hortonville, WI
2021 Rubicon Unlimited
Disconnecting LCA brought it down some.
Eischman
Eischman
Hortonville, WI
I’ll move jack closer to tire also.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
I had the same issue when installing my MC 2.5” springs. Go to Autozone and rent a spring compressor.
Eischman
Eischman
Hortonville, WI
Once I remove this stopper I’ll probably have it!
Jeep Wrangler JL Right side front axle not dropping enough? imag
Eischman
Eischman
Hortonville, WI
Jeep Wrangler JL Right side front axle not dropping enough? image
Eischman
Eischman
Hortonville, WI
?it’s arriving today from Amazon!
Looks like I might be sending it back!
Eischman
Eischman
Hortonville, WI
Thanks everyone
Remorseless
NC
Eischman
Eischman
Hortonville, WI
Done replacing the Buy once Cry once spacer kit!
Next month shocks!
Fox 2.0 or RR
….and get proper jack stands. Those blocks are giving me anxiety ?
I have them but they were not tall enough to get the body high enough for the axle drop.
Remorseless
NC
Next month shocks!
Fox 2.0 or RR
I use this set: Amazon.com: BIG RED T41202 Torin Steel Jack Stands: 12 Ton (24,000 lb) Capacity, Red, 1 Pair : Everything Else
Overkill for a Jeep, but the height is SWEET for a lifted Jeep. My JKR wasn't on a huge lift - ~3.5" - and a set of 4 of those under the frame and you could drop the axles as far as you needed for any work/maintenance on the suspension. Across my and my friend's Jeeps, used these to swap 4 or 5 suspensions around and no issues with any suspension being too tall - tallest was like a 4.5ish inch extra capacity overlanding suspension that required a ton of axle droop to get those stiff springs in.
