AnnDee4444
This is not correct. Tire size & wheel offset has nothing to do with camber.Wide tires and offset rims affect the camber. Many Jeeps run wide tires on offset rims which throws the camber way off.
You “adjust” it with relation of tire diameter vs wheel offset. For example, 33” tires on 10” rims produces more scrub radius (positive camber) than 35” tires on 8” rims with same backspacing.You don't hear it discussed because it can't be adjusted without new ball joints/shims which most don't really recommend.
It does not change the camber angle - it changes the contact patch location on the road. Read the link I posted.This is not correct. Tire size & wheel offset has nothing to do with camber.
You are getting camber & scrub radius mixed up. They are not interchangeable.It certainly does. Read the link I posted.
I understand it very well. The two measurements are not interchangeable - they are related. Camber is used to create a desired scrub radius for a given wheel and tire diameter - the “factory” design. When you change tire diameter and/or wheel offset you alter that scrub radius - which changes the tire contact patch location on the road - which alters the intent of the factory camber selection. The camber angle will still measure “in spec” but the response is different because the tire contact patch on the road is in a different place (i.e., the scrub radius is different).You are getting camber & scrub radius mixed up. They are not interchangeable
Yes, but changing the wheel offset does not change the camber. You stated in "Wide tires and offset rims affect the camber". You could remover the wheels completely and still measure the camber, because it's literally built into the axle (on the JL). Look at how a camber gauge works, and imagine what effect a different sized wheel/tire would have:I understand it very well. The two measurements are not interchangeable - they are related. Camber is used to create a desired scrub radius for a given wheel and tire diameter
I agree.When you change tire diameter and/or wheel offset you alter that scrub radius - which changes the tire contact patch location on the road - which alters the intent of the factory camber selection.
Touché - I should have said it affects the effective camber. As you said, the actual camber angle doesn’t change - which makes this effect hard to see and measure. To maintain the factory scrub radius (effective of camber angle) tire height and wheel offset have to maintain the right ratio.Yes, but changing the wheel offset does not change the camber. You stated in "Wide tires and offset rims affect the camber".
I'm not sure I follow, but I'll try to describe where I think you are going: the measured scrub radius is not equal to the 'effective scrub radius'. Basically, it's how camber effects where the pneumatic center of the tire is located, therefore altering the effective scrub radius.Touché - I should have said it affects the effective camber. As you said, the actual camber angle doesn’t change - which makes this effect hard to see and measure. To maintain the factory scrub radius (effective of camber angle) tire height and wheel offset have to maintain the right ratio.
What I am trying to point out is that changing tires and/or wheels - not just lift kits and control arms - can adversely affect steering geometry. It’s true for all vehicles with modern, 3-trim-axis Ackermann steering. The JL is no exception.I've never seen this discussed online and I'm not sure this has any practical use on the JL, due to it's mild camber angles and large sidewalls.
This isn’t really a mystery, let’s put aside the Wrangler platform for a moment and think about a car or suv you own or owned. How many times in your life have you changed tire brands and the car you were so used to became a different car, sometimes good and sometimes bad. Tires obviously affect steering, handling, braking. and pretty much every aspect of the cars drivability. The JL is obviously a different animal because a large majority of owners completely change what the engineers at Jeep designed. My suspension and steering is unrecognizable from when I picked it up, in a good way though.What I am trying to point out is that changing tires and/or wheels - not just lift kits and control arms - can adversely affect steering geometry. It’s true for all vehicles with modern, 3-trim-axis Ackermann steering. The JL is no exception.
I really hope you didn’t do all this chasing a ride your JL isn’t capable of producing in the first place. By no means do you need a track bar relocation bracket. The track bar should run in line with the drag link, and without a lift over 4” you shouldn't change either. You’ll just cause more problems!Update - removal of the Teraflex Apline IR track bar and reinstall of the OEM provided a positive outcome. Possibly the need for a Teraflex front axle bracket kit? Not sure why, but possibly the additional caster causes a geometry issue similar to a lift (mine is stock JLUR). Please go easy on me as I am pretty green in all of this.
I talked to the PSC technician yesterday and got some clarification on positive caster setting. It seems the +6-+7 caster is for tires in the 37+ range. I was told to ease the caster back to +5.x for some balance between handling and return to center of the steering wheel. Of course this means the need for adjustable LCAs as the stock LCAs will only provide +4.x and the longer Mopar (1/4" longer) provide +6.x.... So to get between, I need 1/8". I think once I get this set, I will have it as good as it can get.
Trial and error seems to be best medicine to get my Red Rubi where she needs to be.
You shouldn't change your track bar without a lift over 4"? That's not very good advice at all. First of all, the factory track bar is junk. Any amount of lift is going to pull your axle off center, how much you want to put up with is up to you. Agree that the track bar bracket is not necessary unless you flip your drag link.I really hope you didn’t do all this chasing a ride your JL isn’t capable of producing in the first place. By no means do you need a track bar relocation bracket. The track bar should run in line with the drag link, and without a lift over 4” you shouldn't change either. You’ll just cause more problems!
I think you misunderstood me, I meant he shouldn’t relocate the track bar, not shouldn’t change it. He mentioned a track bar bracket which I assume he means a relocation bracket. I also meant that he shouldn’t be relocating the track bar or flipping the drag link without a lift of at least 4”.You shouldn't change your track bar without a lift over 4"? That's not very good advice at all. First of all, the factory track bar is junk. Any amount of lift is going to pull your axle off center, how much you want to put up with is up to you. Agree that the track bar bracket is not necessary unless you flip your drag link.
