Steering Wheel Return to Center
NVULLC11
Bruce
PA
Jeep Wrangler Willys 2025
Hello, so I notice unlike most cars that when turning, the steering wheel returns to center on its own. My Jeep Wrangler Willys 2025 does not, maybe a little but mostly needs to be manually straightened out to center when finishing the turn. For example, say you are at a red light or stop sign and making a right or left turn, normally after completing the turn, the cars steering/tires will return to center on their own. My Jeep Wrangler Willys 2025 does not, it is all stock besides the MOPAR extended LCAs and just recently installed the FOX SHOX ATS 983-02-148. I honestly don't remember if the steering wheel returned to center before I installed the FOX SHOX ATS 983-02-148, if I were to guess, it did or at least wasn't as bad. I do have the FOX SHOX ATS 983-02-148 setting at 18 clicks.
Any help of advise as to what to check for or is this normal?
Old Dogger
Bill
Cave Creek Arizona
Since it is a 2025, your steering linkage and ball-joints, are probably somewhat still on the tight side. They will loosen up. But positive caster is what is needed to help it return.
kah.mun.rah
Merenkahre Jr.
Duat
Adding the longer LCAs should have actually made it better. I agree with the Old Dogger comment above.
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
A stiff steering stabilizer will hold the tie rod at whatever position it is in until there’s enough force to overcome it. Stiff stabilizers also put extra load on the power steering pump…..
Rob1833
Rob
Pennsylvania
2023 Rubicon JL, 2025 colorado Zr2
I have a 2023 with 32000 miles on 35'S with the same issue and a little bit of walk but for the most part pretty straight, should I get it aligned? Thanks
rickinAZ
Rick
Phoenix
2026 MOAB 392
@NVULLC11, I had the same return-to-center issue when my JL was new. I also had a slight pull to the left. The OEM steering stabilizer is a pressurized design that can tend to create a pull. I installed a Falcon Nexis 2.1 damper (pull-through design) and my issue went away. I also have longer (adjustable) LCAs. That said, it sounds like you have both of those mods already. Maybe your damper is binding. Have you tried driving it damper-less to see if the centering corrects itself?
rickinAZ
Rick
Phoenix
2026 MOAB 392
Have you measured your caster? Are you running stock LCAs? Rubis suffer from too-short LCAs anyhow and it sounds like you might have some degree of lift to fit 35s - which would exacerbate it. Your caster should ideally be roughly 6°. Its an easy DIY measurement with a (downloaded) angle finder. Or... buy one of these for a easier, more precise measurement. The magnetic base makes for a more steady placement: https://www.amazon.com/dp/B0F6ND2ZJG?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
NVULLC11
NVULLC11
Bruce
PA
To be honest as I am not that smart when it comes to parts on cars. What is a damper?
If you mean the Fox steering stabilizer ATS, I have it set to 18, might be too high? I have not tried to adjust it yet.
NVULLC11
NVULLC11
Bruce
PA
I had my dealer install the MOPAR LCAs which are a tad longer and the Jeep is factory Willys, no additional lift or bigger tires.
rickinAZ
Rick
Phoenix
2026 MOAB 392
Yes, I did mean steering damper. You may be set too high or you may even have a faulty (binding) damper. The damper-less test will tell you right away. I know you downplayed your car knowledge, but removing and reinstalling the steering damper is very basic - no mechanics skills required, just a wrench. If you remove the damper and the problem goes away, you've got your answer. As a first step try setting it to the middle setting (12?) on your scale and test drive. Most people with adjustable steering dampers drive 99% of the time in the middle setting.
