Remove skid plate before dealer visit?
jg45
Bartlett, TN
2020 JLUR Recon
My transmission has been shifting hard/shuddering on the 1-2 shift when warmed up for almost 2 years. I have ignored it because of the local dealers being so backlogged that it would be sitting for 6+ weeks to get looked at. My 3/36 basic warranty is about to expire and I am thinking of taking it in. I have an Asfir engine/transmission skid plate installed. Should I remove that before taking to dealer? Do they care about skids and will they want to charge me to remove and reinstall it?
Cuyose
Shawn
Piedmont, SD
2020 Jeep Wrangler Rubicon
Data Analyst
I would bet they charge you for having to deal with it, if its easy I would remove it. Would also remove the possibility one tech removes it then after buttoning everything up its laying on a shelf somewhere, or they strip bolts using an impact wrench etc.
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
I wouldn't trust a dealer to remove/replace aftermarket skids. Most likely you'd be charged for the labor involved. They're not gonna properly torque the bolts... they may lose one.
Heimkehr
Pennsylvania
2021 JLU 2.0T
My transmission has been shifting hard/shuddering on the 1-2 shift when warmed up for almost 2 years. My 3/36 basic warranty is about to expire and I am thinking of taking it in.
Best of luck with the transmission issue. Tangentially, my selling dealer refuses to change the fluid in mine, even if I supply all necessary parts, deciding instead to lean on the "Lifetime Fill" language in the Owner's Manual.
As for the skid plate, yes, I'd suggest you'll be dinged for whatever labor expense can be assigned to its removal and reinstallation. The risk of having dealer staff do so (specifically, the potential damage caused by negligent use of an impact wrench) would compel me to remove it myself before the vehicle ever sees the Service Dept. Just a thought.
Pig-Pen
Banned Camp
2018 JLU
jabroni
They may say they wont touch it till its removed.
roaniecowpony
Retired Engineer
Labor time is $$ and someone has to pay for the time. Nobody rides for free.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Whether they charged me or not, I'd remove the skid plate out of basic courtesy. I added it, it will likely be in their way, so I'd remove it. It will remove headaches for everyone.
linux_guy
Alabama
2020 JL 6-speed manual, 2011 Compass 5-speed manual
By that logic, it would be nice if a rotate and balance job covered five wheels. IfJeeps came from the factory with seven wheels, I would expect a seven wheel rotate and balance job.
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
Aluminum skids? Shouldn't be that hard to do yourself. (I recently--on garage floor--dropped/reinstalled a couple of the plates to access frame rail for hitch wire install). Dealer will certainly charge for labor and--how much trust do you have?--maybe mess up something.
Reinen
Utah
The thing with tire rotations is that there are multiple ways to do it, it's not just 4 or 5 tire rotation and there isn't a single right way to do it. What matters is that it's always done the same way.
No matter how competent they are, different techs will rotate tires in different ways. Do it yourself so it's always done the same way.
