Remote Start Issues Aux Bypass
jna97
Jason
Houston TEXAS
2024 Wrangler Rubicon X
Engineer
Bought my daughter a used ‘20 Sahara Altitude in October. In November the battery died, so replaced it with an Autozone Duralast 35DL. Everything works fine except the remote start started working sporadically. I figured it was the aux battery so tried to replace this morning. When I removed the last cover (i went from top) I was surprised to find there wasn’t one. After doing some research it looks like the previous owner bypassed it. My question is other than reverse the bypass at the dealer what are my options? Can I get an H7 battery and all good? There aren’t any lights or messages currently. Posting a pic of the negative terminal and battery receipt i used. I compared the negative terminal to my ‘24 Rubicon and it’s definitely different. However i have the factory tow package. Any help appreciated.
Jeep Wrangler JL Remote Start Issues Aux Bypass IMG_0294
Jeep Wrangler JL Remote Start Issues Aux Bypass IMG_0296
AndySpill
Andy
Pittsburgh
2018 JL Sahara
From some quick research it seems the Rubicon X of which you speak comes from the factory with dual AGM batteries. If this is incorrect the questions I'm about to ask you to get answer to won't be appropriate.
It seems from your picture that the prior owner yanked the cable that connects the negative terminal of the ESS/Aux battery to the main battery's negative terminal.
Usually this is done in concert with other steps.
In the dash (the EVIC) do you see an ESS off light? This looks like the letter "A" with a near circle around it following by an exclamation point?
Find the PDC. It's that black box near the top of the engine bay near the passenger's seat. Take off its cover. Find Fuse 42. There's a fuse map on the inside of the PDC's cover. Does Fuse 42 seem to be pulled out?
In the PDC locate the corner closest to the driver's side and front of the vehicle. You'll see a connection post for cables. We'll call in N1. Next to it, no surprise, is N2.
Has any wire been placed between these two terminals?
Based on your answers we can move forward from there.
I'd prefer to not write novels until I have a better understanding of what is going on under your hood.
jna97
jna97
Jason
Houston TEXAS
Engineer
Thx. Will post some pics and do some checking when she gets home.
TheNewGuy
Wes
NH
My money is on the Sahara having the 3.6 with eTorque.
jna97
jna97
Jason
Houston TEXAS
Engineer
Pics of the fuse box. Looks like 42 is gone. The motor is a 3.6L.
Jeep Wrangler JL Remote Start Issues Aux Bypass IMG_0309
Jeep Wrangler JL Remote Start Issues Aux Bypass IMG_0310
jna97
jna97
Jason
Houston TEXAS
Engineer
That’s a good question. I can’t find anything on the paperwork. Here’s a pic. Man…feel helpless lol.
Jeep Wrangler JL Remote Start Issues Aux Bypass IMG_0314
JLfromCA
JL
2019 Mojito! 2 Door Rubicon/2024 Sarge Green 392
looks like E Torque generator. So it would have no aux battery or fuse 42. It does however have a 48 V battery under the jeep. Take it to the dealer.
jna97
jna97
Jason
Houston TEXAS
Engineer
Thx guys!
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
Another clue this is an etorque is that there isn't a cable on the N3 terminal and there is a metal shunt connecting N2 to N1.
jna97
jna97
Jason
Houston TEXAS
Engineer
I wonder if I got the wrong main battery since I didn’t know it was an etorque?
21 Willys
Shoals Junction, SC
2021 JL Willys Sarge Green
Just spit balling here. Any chance the key fob battery is going south?
jna97
jna97
Jason
Houston TEXAS
Engineer
Replaced the FOB battery the same day.
