ECGS HP60 - 40 spline inner / outer bigbell RCV's and 4" axle tubes...just got the control arms bolted up and have NOT cycled yet, but wow trackbar seems really close to end of filter.What axles are you running? I’ve dented my larger SRT oil filter getting a little too spirited off road but that was from the upper control arm mount smashing into it. I’m running Dynatrac XD 60s.
Until you cycle it unfortunately you won’t be able to really determine what you need to do. I’ll take another look at mine today to see what exactly is hitting the oil filter. Been a while since I’ve crawled underneath it, mine is still muddy from the last Windrock trip I did. Bumpstops and pushing the axle forward will probably be your best bet.ECGS HP60 - 40 spline inner / outer bigbell RCV's and 4" axle tubes...just got the control arms bolted up and have NOT cycled yet, but wow trackbar seems really close to end of filter.
- I can close down bump stops limiting up travel
- Add taller springs (currently running Synergy 4" springs which claim 2" for 392)
- Relocate filter but I swear I read others having trouble finding a remote kit that does not leak at the block, but I can't find those threads and may have dreamed it or else it is somewhere across 4 social media types and can't find it again)
- 99% sure doing nothing will end catastrophically!
