chevymitchell
- Shawn
- Feb 18, 2018
- Pueblo West, CO
- 2022 392XR, 2025 Wagoneer S, 2006 LJ 6-spd
- Occupation
- Avi Engineer
Why not use the off-road pages?One thing about the Reid knuckles is that you need to grind the cast steering stop to facilitate full factory steering movement/turning radius.
I used my 4" DeWalt angle grinder with a composite abrasive hard disc (radiac wheel to you other old guys). It took about 3/16" of removal to get it to the OEM turn angle.
To measure the OEM turning angle, be sure to measure it with the OEM knuckle installed. I removed the brake caliper, disconnected the tierod from the OEM knuckle, rotated the knuckle against its stop, and used a straight edge (I used angle aluminum) to lay across the brake disc and mark the frame with chalk. This became the reference point for grinding the Reid knuckle. It was quite a lot of difference of turning angle to adjust (by grinding the stop). This picture shows when I was getting closer with the grinding. It started out about 3 or 4 inches away from my reference mark.
…… my Reid stops were less than a 1/4” longer so I left them alone, shhhhhh…..
