Rear trac bar bracket measurements?
Dark Eternal
Seattle
While installing a Rock Krawler long arm on my 392, I got a little ahead of myself and cut off the rear trac bar bracket without recording the placement of the mounting hole.
Could anyone with a rubicon (wide axle) take a quick measurement for me? I need the horizontal distance between something like the flange at the end of the axle where the ABS sensor mounts, to the trac bar mounting hole on the axle. Just need to know where to weld the new trac bar bracket on!
Thank you!
Roky
Roky
Thank you!
I’m running that kit, I can get you an exact measurement where to set it when I get home this afternoon……
Dark Eternal
Seattle
That would be amazing, thank you!
You would think I would see the giant bold letters saying to take that measurement, but no!
Roky
Roky
It’s 3/4” from bump stop plate and 6-7/8” from the round edge of the flat on the diff…..with the adjustable bar, you don’t have to be perfect on this……if you have your truss on already it sits pretty close to it……
Jeep Wrangler JL Rear trac bar bracket measurements? 8CC67471-E177-4F83-9366-A26D4659C7A1
Jeep Wrangler JL Rear trac bar bracket measurements? 45DBB2AF-292B-4AE2-926C-9F540B7EB7C6
Jeep Wrangler JL Rear trac bar bracket measurements? 4DDC6044-A58E-4582-B7DC-E789BBD30456
Dark Eternal
Seattle
This was exactly what I needed, thank you!
now I just have to figure out the exhaust on the 392. The cats are right where the front control arm mounts need to be!
Roky
Roky
Sure no worries, if you need anything else reach out……
