Rear Sway Bar
BellValleyAT
Greg
Rhode Island
2025 JLUR
I was today years old when I learned that JL's might have a rear sway bar? Is this true for all models?? Did that get added with the JK? I don't recall TJ's having them?
Does it limit articulation as much as the front sway bar does?? I assume not as much else the Rubicon would have rear sway bar disconnects?
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
I'd guess that stability requirements make it so that a rear sway bar is mandatory on JL's. I originally left mine disconnected after doing a lift. After a month or so of terrifying body sway at highway speeds I decided to connect it up. There is a noticeable difference between connected and disconnected. It's a 15 min process to take it off if I really think I need that much articulation on a trail.
BellValleyAT
Greg
Rhode Island
2025 JLUR
Thanks! With it connected, is articulation as limited in the rear as it is with the front connected?
Roky
Roky
The rear swaybar is more like a torsion bar or torsion spring…. It is designed to twist when articulating. It actually helps in some situations to keep it connected…..
azwjowner
Phoenix
The rear sway bar actually improves articulation, as counter-intuitive as it seems. There are videos on Youtube somewhere.
Roky
Roky
I've never taken the time to put it on a ramp and measure so no idea really.
I’ve tested mine, and it does not limit flex…..in this pic my shock is fully extended….
Jeep Wrangler JL Rear Sway Bar IMG_8015
Jeep Wrangler JL Rear Sway Bar IMG_0374
flick2614
Randy
AZ
Nice. Are you running 2.5's in the rear?
Maverick909
I.E.
with a 2.5" lift i have never needed to disconnect my rear sway bar. ive done multiple badge of honor trails with no issue. i dont plan of removing it while on the rubicon trail next year either
flick2614
Randy
AZ
Thanks…. Are talking about shocks or springs ? Shocks are 2.5s front and rear, springs are 3.5”…..
Shocks. Are the 2.5's stiff at all when crawling?
Roky
Roky
No, they’re pretty sweet…. We usually set both dials on 1 when we’re doing slow stuff… with tires at 10 psi sway bar disconnected and shocks on soft, it’s a very comfortable day…
