Rear Locker says engaged. Sensor replaced did not fix.
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
I have a 2020 JLUR.
I potted both of my sensors very early into ownership (first few months) and have never had issues.
last week my rear locker said it was engaged in 2wd…but it wasn’t. I put it in 4 low, engaged the locker and confirmed it engaged then disconnected. The light flashed but never confirmed disengage, although it was in fact disconnected.
i ordered the z-automotive sensor fix and the replacement internal sensor.
the z automotive fixed the issue as expected.
today I opened the differential and swapped the sensor. I cleaned the magnet and all the area around the sensor before installing.
immediately upon Turing the vehicle on, it says the locker is engaged.
I did a few cycles of engaging disconnecting and it behaves the same as before swapping.
The only part left in the equation appears to be the wire harness internally.
does this sound right, or is there something else I should look for? I have to open it again as I have a leak now on the differential. If the harness is easily replaced I may try that, otherwise I am going to hit it with electronic cleaner to see if maybe oil got into the connector.
kah.mun.rah
Merenkahre Jr.
Duat
Where did you get the sensor? They come in a kit with 5 sensors and you have to do a trial and error to see which one in the kit works for your Jeep.
Redbaron73
Redbaron73
Ronnie
Well that explains it. I got it from eBay and only bought a single. Should have paid better attention.
oldcjguy
Jim
Central FL
16 Challenger Hellcat, 19 Challenger Scatpack, 20 JLUR Recon
Software Engineer
Also, if the Z Automotive patch worked, it's not your harness (at least up to the diff) because that still uses your stock harness.
Martial Fartist
Christopher
Spring Hill, Florida
When I recently had the sensor failure, the dealer said the issue isn’t always directly the sensor, something about oil getting in to the wiring. Which I’m guessing is why they did a full axle housing replacement on mine.
kah.mun.rah
Merenkahre Jr.
Duat
My guess is that someone bought the kit with 5 sensors, found the one that works for their Jeep and then are selling the other 4. If so, problem is that those that buy the other 4 individually only have a 1 in 5 chance that the one they bought is compatible with their Jeep.
