Rear Cargo Shelf
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
How is the build quality? And how solid is it when up or down?? I have been eyeing this as i like the flexibility.
It's very solid up and down. It's sturdy and is attached well. It's rated for 350 lbs, I don't see how you could get that much weight on it though unless you were stacking lead bricks. If you want to remove it completely it's only 4 bolts with big knurled knobs so no tools are required.
weeitsmikelee
Michael
New Jersey
‘21 Wrangler 392; ‘22 Grand Wagoneer; '15 Harley Sportster; '82 Honda Silverwing
Healthcare
Does the top expedition shelf fold down for loading, or do you just shove stuff up there?
It’s only adjustable height wise - there’s no folding/swing function so you just shove stuff up there.
There’s probably a dozen members now vouching for it. It’s a good product.
MVOffroad
2021 Jeep Wrangler Rubicon
I have both the shelves from Expedition. I love them. Bigger one isn't fun to assemble, but the installation is super easy for both. Solid. No rattles. Adjustable. Look good. No complaints
@Ecorubi I like this setup! Are the XG cargo bags still easy enough to get into? Also what is the height between the two shelves? I have an ecoflow delta 2 max power station I'd like to set on the lower shelf and want to make sure it'll clear.
Ecorubi
Israel
Kansas
2021 Rubicon Ecodiesel
It's 11.5" from the lower platform to the upper. There is a 1" lip on the lower shelf. I have the lower shelf at the lowest setting and the upper shelf in the middle. It could raise about an inch if it was at the highest level. Cargo bags are easily accessible. I have the SOT top so my back windows pop in and out pretty easy which makes installation/removal simple. Once installed, they access fine.
MVOffroad
@Ecorubi Thanks for the info! I think there is a chance I could get this to work. The ecoflow delta 2 max is 12" tall exactly and 16.25" long (footprint). I'm thinking I could probably set it on the shelf sideways to clear the lip and then rotate it under the upper shelf if I raise the upper shelf a bit higher.
CWRUYOTE
CLE
2021 JLURD
Just finished installing the lower cargo shelf from Expedition and was test fitting the XG Cargo Gama bag....
Jeep Wrangler JL Rear Cargo Shelf IMG_7699
TEAMSLO
North Las Vegas
23 392, gone 21 JTM & 22 JLURD
Not so good at least for me, had it for a short while. The knurled knob had a weld or pinch of some sort which broke off the bolt making it useless. Also didn't work for me as their mounts got in the way of my quick release fire extinguisher mounted to the cpillar. This one below isn't the one that broke, but you can see where it would fail.
Jeep Wrangler JL Rear Cargo Shelf 20250619_111833
Went back to old faithful with the American Adventure Labs MASS shelf.
Jeep Wrangler JL Rear Cargo Shelf 20250619_111912
I have also used hooked and ARS (metalcloak affiliated company) on past rigs. The hooked one was cheaper but did ok with a few rattles. The ARS was solid and even had sides pieces predrilled for a twin arb compressor which I used. No issues there, just won't work on my new rig.
JZK
Nebraska Panhandle
22 Rubicon 4xe
Another vote for the Expedition. Sits super high but still get all my recovery gear on it. Got a cargo net on Amazon to help hold all the bits in place.
tk1700
Tom
New Mexico
@tk1700 How is this holding up over time - I ran across it and was thinking about getting it. Thanks!
It's holding up great. The only issue I've had is the knobs that hold it in place loosen after an extended time on washboard roads. They will start to rattle and I just tighten them by hand. I don't want to use loctite since 2 have to be removed to adjust the shelf. I'm going to make some rubber washers out of inner tube or similar material and see if that helps. The net that comes with it is ok. It's easy to secure things on the shelf with cargo straps.
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
I have one for sale (Hooke Road) in the classifieds in anyone's looking for one.
