2019 JL Rear Cargo Shelf
sychan29
Virginia
2020 JLU
Do any of these options work with both a hard top and a soft top?
Sprint7
Louisiana
2004 LJ 2018 JL
How did you secure the slider? Did you remove the cargo hooks and use those bolt holes? I've been considering the DFG and Hooke so great to see.
Sorry for the late reply. I have four bolts holding down the DFG slider. Three are using the bolt holes from the cargo hooks and I have one bolt through the tub in the rear of the slider on the other side. Been on a lot of trips and zero issues. I did have to trim the slider to fit. If I can find a pic I will add it later.
Also, I think the Hooke will work with the 37qt but I have the 50 qt and had to raise the shelf up about 1.25" for the fridge to fit under. I have had this setup for about a year and it has worked well but I am about to change it up. I would like a shelf that can stay easily stay on when I remove the top so I am going to fab up some brackets that mount the shelf to the cage.
benb
Ben
Oregon
2018 JLU Sport-S-KIA; 2020 JLU Rubicon
ARB 37, Goosegear plate, AAL fridge slide and AAL cargo shelf.
Wow, that shelf looks awesome. Can you tell me the height adjustment range for it (Space on the bottom)? I want to make sure I can fit my fridge, but their website says TBD for the height.
How long did it take to get yours?
lembowski
San Diego
2018 JLUR Sting Gray
I have it mounted in the lowest possible spot and it is 18.5” from my Goosegear platform to the bottom lip of the shelf. With my 37qt on the AAL fridge slide I have a little over and inch clearance between the lid and bottom of the shelf. I included a picture of the side mount and how it is maxed out by the plastic rollbar covering. Moving it up to the max the bolts move up 2.5”, so at the max setting you would have 21” if you also had the Goosegear plate. So assuming you have a fridge slide that is low profile a 50qt ARB should fit well at the max setting. As for the AAL plate or stock floor I can’t speak to that. I was the 1st to order and ship, they actually shipped mine assembled since they used it for product shots for marketing.
benb
Ben
Oregon
Thanks Dude, that will work for my setup. Order placed! Hopefully the lead time is not too long.
m3lover1
Ricky
Bay Area, CA
2019 Sting Gray JLUR, 2007 Yamaha R6
I also have the AAL shelf, just installed couple days ago and absolutely loving it. I have it at the lowest possible setting too as my Roam box fits underneath, and to give more room up top. Once I get the fridge then I might have to adjust.
MaggieJeep
Maggie
Melbourne, VIC
MY20 JLUR Granite Crystal
Architect
Hey mate. Can you do me a favour. Can you measure the distance from the cargo shelf to the front seats? I need to know if I can fit my current dog crate in the backseat folded down area.
Much appreciated mate.
lembowski
San Diego
I’ll try to get the rack back in this week to take a measurement. Had to take it out to get a new deep freeze home.
m3lover1
Ricky
Bay Area, CA
It's 37.5 inches from the shelf directly to the back of the front seat, the topmost part of the seat before the headrest. Hope this helps.
neil
neil
Dallas, TX
20 JLUR, 21 JLUR and others
curious what finish you ordered on that AAL rack?
Just ordered the satin on mine. Your's almost looks 2 tone
lembowski
San Diego
Textured black, got the Versatable in the same also.
Morris 4x4 Center
