ScotM
- Scot
- Jan 3, 2023
- Southern California
- 2022 Jeep Willy's JL 2 Door
I did the mopar 2” lift, and was wondering if the rear axle should be perpendicular to the ground , just as the front is. I installed adjustable control arms, but set them at the same length as the stock, and the angle is about 9.4 degrees negative at the rear. My front is about 0.4 negative. Both measurements being off the differential flat spot at parallel to ground. Going to shop to have it aligned, but just wanted input from the jeppers here. Thanks!!
